How common is a dead spark plug?
I have been chasing an engine miss. This weekend I found out I had a dead sparks plug. It was not firing at all. Found out because I put my timing light on each wire to see if I had broken a wire connector while putting on my new tall manifolds. There was no physical evidence of anything being wrong. No massive build up, no broken insulator. Put in a new plug and presto, it runs on all cylinders and timing light flashes as it should.
How common is this? I have never heard of it, fouled yes, not working at all never.
Rob Richardson
1974 911S
Carbed RS Clone engine
Turbo flares
2009 Carrera S - Porsche Racing Green, PDK
Old 12-01-2009, 06:17 PM
Grady Clay's Avatar
Rob,
That isn’t a common issue but I understand exactly what you describe.
This is the reason that everyone chasing some misfire gremlin should start with a new set of sparkplugs. Racers typically have a run-in and tested set as a diagnostic tool.
Good that you found the problem.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 12-01-2009, 06:48 PM
Senior Advisor
James Brown's Avatar
it happens, check the resistance from the electrode to the case if it's infinity, there is a open in the plug, if there is a high (greater than 15k), it's too much for the spark to to jump. I do this every time I clean or replace plugs. sometimes, you get a bad one from the factory-it just happens.
08 Cayenne Turbo
I have to say I have never heard of a plug that just did not work. The good news is that is was a easy & cheap fix. That does not happen often.
Old 12-02-2009, 05:41 AM
scottb's Avatar
I recently had a problem with what felt like low power in the helicopter. The old spark plugs all looked fine, but we replaced them anyway with a new set. The difference was like night and day!
Grady's advice is good -- using a new set of spark plugs provides a baseline, and eliminates the plugs as a potential source of the problem.
1984 Targa
Old 12-02-2009, 12:12 PM
dshepp806's Avatar
and not a wallet-breaking event, either.
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-02-2009, 03:19 PM
