How common is a dead spark plug?
I have been chasing an engine miss. This weekend I found out I had a dead sparks plug. It was not firing at all. Found out because I put my timing light on each wire to see if I had broken a wire connector while putting on my new tall manifolds. There was no physical evidence of anything being wrong. No massive build up, no broken insulator. Put in a new plug and presto, it runs on all cylinders and timing light flashes as it should.
How common is this? I have never heard of it, fouled yes, not working at all never.
Rob Richardson 1974 911S Carbed RS Clone engine Turbo flares 2009 Carrera S - Porsche Racing Green, PDK |
Rob,
That isn’t a common issue but I understand exactly what you describe. This is the reason that everyone chasing some misfire gremlin should start with a new set of sparkplugs. Racers typically have a run-in and tested set as a diagnostic tool. Good that you found the problem. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Senior Advisor
it happens, check the resistance from the electrode to the case if it's infinity, there is a open in the plug, if there is a high (greater than 15k), it's too much for the spark to to jump. I do this every time I clean or replace plugs. sometimes, you get a bad one from the factory-it just happens.
08 Cayenne Turbo |
I have to say I have never heard of a plug that just did not work. The good news is that is was a easy & cheap fix. That does not happen often.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I recently had a problem with what felt like low power in the helicopter. The old spark plugs all looked fine, but we replaced them anyway with a new set. The difference was like night and day!
Grady's advice is good -- using a new set of spark plugs provides a baseline, and eliminates the plugs as a potential source of the problem.
1984 Targa |
and not a wallet-breaking event, either.
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Thread Tools | |
Rate This Thread | |
