Trans Shift Help Needed-- Can't Shift..
I went to park my 86 930 this evening and when I went to select reverse, I felt a bit of a pop and noticed I wasn't feeling the tension when I push to the left on the shift knob.
The shifter will not move into 1st, 2nd or reverse. No grinding, it just won't budge more than say a few MM or so regardless whether the car is on or off, clutch in or out.
3rd and 4th are totally fine.
I checked the shift coupler linkage and I'm spot on, I just can't select any gears on the driver's side of the shift tower.
Any suggestions before I have her flat bedded to the shop? Car is stuck at a friends.
Thanks!
Mike
1986 930 Turbo (Stock) 39k
Huntington Beach, CA
Old 07-30-2009, 06:56 PM
check the linkages and coupler. After that, you may need to open up the tranny.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-30-2009, 07:41 PM
Rear coupler is adjusted properly. Is there another linkage that I should check? Where is the spring that gets pushed in to engage reverse located?
Thanks!
Old 07-30-2009, 08:21 PM
It is underneath the shifter, inside the shift housing. You access it by removing whatever middle console you have and then pull up the carpet.
Old 07-30-2009, 08:43 PM
gearhead
When you start the car and release the clutch, is the car in reverse or neutral?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-31-2009, 06:29 AM
kodioneill's Avatar
Take off the small rectangular cover on the side of the transmission and see if the bracket is tight and attached.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 07-31-2009, 06:53 AM
Neutral, won't go into reverse.
Off to the shop it goes..
Old 07-31-2009, 08:21 AM
