Science is NOT optional
rbogh901's Avatar
Thumbs up RSR clone, 2.7 or 3.6
There are those who say that a 3.6 conversion is financially not much different from a good 2.7 build. Certainly there are pros and cons. Authenticity and weight are considerations but so are power and efficiency.
This must be covered somewhere but I'm not finding it when I search. Maybe not the right search terms.
Old 08-05-2009, 03:43 PM
Clone...... 3.6
Highly original RSR clone..... 2.8 + lots of $$$$$$s. This car was recently built by Kevin Jeanette of Gunnar Racing.
About as close as you can get to an actual RSR......
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
Old 08-05-2009, 04:42 PM
ninelevenick's Avatar
Wow, that is GORGEOUS.
Old 08-05-2009, 06:08 PM
deshetlr's Avatar
So did you drive it to Keystone?
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 08-05-2009, 06:12 PM
Not mine, but yes it was driven by its owner Lee a fellow Pelican.
75 911M 2.7 MFI
19 991.2 S
Old 08-05-2009, 06:42 PM
Administrator
Jack Olsen's Avatar
What do you want to do with the car?
Old 08-06-2009, 08:19 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Look at it from the other side. if you were looking to buy one, would you rather have the one with a 2.7 or the one with a 3.6?? me?? 3.6, no contest..
Old 08-06-2009, 02:41 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Do you know where those seats were sourced?
Gary R.
Old 08-06-2009, 03:57 PM
I believe GTS. xtra wide STs
75 911M 2.7 MFI
19 991.2 S
Old 08-06-2009, 04:21 PM
GaryR's Avatar
I thought so but thanks for the confirmation. I would get the wide set also as it's for a road car..
Gary R.
Old 08-06-2009, 04:50 PM
Back to the last pertinent question; what do you want to do with the car? If I had my last 2.7 build to do over again, it would absolutely be a 3.6. They have great power, still use pump gas (if you build a hot rod 2.7, raise the compression ratio, it requires higher octane), and, the 2.7 is noted for leaking, errr, marking it's territory.
Old 08-06-2009, 05:45 PM
DW SD's Avatar
3.6 is a very user friendly package. You can still do it vintage looking with ITBs, carbs, too.
Doug
1971 RSR - interpretation
Old 08-06-2009, 06:35 PM
