1986911's Avatar
Are these threads stripped??
I had the hardest time getting one of my oil cooler lines off. After removing and inspecting I know why. Apparently a previous wrench improperly tightened this fitting. The threads on the line are fine its just the cooler thats damaged.
Should I
A: Re install and cross my fingers.
or
B: Try to find out thread size and use a die to re thread. (any one know it?)
I removed the cooler to install an Elephant Racing fan. Below are some before and after pictures of that infamous horn bracket. I will be cleaning, welding and painting the bracket tomorrow. Its just mocked up now, held together with hot glue to double check proper fitments. I would appreciate any input on the bracket mod. It would really suck to get it all done and find out it didn't work. I extended the holes 2 inches.
Before
Mocked up before welding
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 08-16-2009, 05:30 PM
DanielDudley's Avatar
They look galled not stripped. If you cant find a die, you can use a thread file, or an ordinary file, or even a fine hacksaw blade, which can actually work well, as you hold it at an angle and it rides the threads.
Know any machinists ?
Old 08-16-2009, 05:51 PM
porsher
aston@ultrasw.c's Avatar
Yikes. The fitting on the right looks ugly.
If the thread root is full of crap then it can be cleaned out as descibed. But if the thread form is missing then I would junk it.
With the combination of heat, pressure and vibration you need a reliable joint.
Old 08-17-2009, 01:13 AM
KTL KTL is online now
Schleprock
KTL's Avatar
A friend booged the threads like that on his '86 years ago. Sent it to Otto's in Venice, CA and he put a new fitting on the cooler. That may be an option if you can't clean the threads. Those threads are going to be hard to clean and make operate smoothly. I recently replaced my aux. thermostat and one of the oil line nuts looked fine but wouldn't go on the t-stat smoothly. Had to pick and scrape it to get some tiny crud out of the bottom of the threads. Point being is your whole fitting is booged, so it's going to be hard to clean smoothly, evenly with a die. Plus a die that size is going to be EXPENSIVE. Hopefully you can find somebody who already has the die and borrow it?
I know Pelican also carries a thread saver for instances like this. But I believe it's for the aux. thermostat fittings. Not sure if the front cooler fitting is the same diameter as the thermostat?
Kevin L
'86 Carrera "Larry"
Old 08-17-2009, 07:17 AM
1986911's Avatar
I'm going to give it a whack with a thread file and hacksaw blade. I will post the results asap!
If the results are not satisfactory I try my luck with a die. Any one know the size??
Old 08-17-2009, 04:34 PM
Walt Fricke's Avatar
MG
I think it is something like 32mm. I'd look it up (you can purchase adapters so you can switch to -AN lines for aftermarket front coolers of various kinds, maybe our host has them, or Pegasus - or measuer - I have a spare in my toolbox), if I thought you ought to invest in a die.
But you should not.
Invest in a proper thread chaser. Looks like a square cross section file, sort of. Each side has file configurations for different thread pitches, which run half its length, then change to another pitch. So you get 8 pitches on one tool, maybe 10" long. Every one should have one of these in his tool box. They do a fine job a lot quicker than hacksaw blades, or even a good jewler's file with a fine edge so you can get down to the thread roots without buggering them up. Sure, not quite as quick as a chasing die, but those have to be megabucks for a one time tool at this size. The chaser you will use forever.
Walt Fricke
Old 08-17-2009, 06:34 PM
Less brakes, more gas!
euro911sc's Avatar
If you can find a nut that matches the threads you can take a dremel with a very thin cut-off wheel and put a slice in the nut all the way through from the outside to the threaded inside. Try and keep the edge as flat as possible and do not round it off, especially on the inside where the threads are. This will create a nice thread chaser that you can use to clean out the threads. Then, after you have run it through at least once, you can use some vice grips to put some force on it and close the newly cut gap slightly. This will cause the threads of the nut to gently re-form the threads of the fitting.
Enjoy!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-18-2009, 06:15 AM
euro911sc's Avatar
PS Your fitting will be a little bit looser fit now, but with the right tape/non-hardening sealant you should be fine.
-Michael
Michael
'13 Cayenne GTS
Old 08-18-2009, 06:17 AM
Michael
Great idea. I have cut slots in bolts to form field expedient taps. Never thought of doing this with a nut for a die.
Walt
Old 08-18-2009, 08:23 AM
Enjoy!
-Michael
Good call !!
Old 08-18-2009, 03:45 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by DanielDudley View Post
Good call !!
Great post.
And don't forget some tapping/cutting or 50W oil.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-18-2009, 04:39 PM
