ischmitz's Avatar
Send a message via Skype™ to ischmitz
Rick, I assume what you plotted is a spice simulation, right.
The 3.2 ignition works just like a simple Kettering ignition. The only difference is that the points are replaced by the darlington transistor in the DME. It switches GND to the coil for the dwell time (charging it) and then turns off. There is a current feedback to limit the charge current through the coil.
Once the darlington turns off the magnetic field collapses and that is what produces the high-voltage spike on the secondary.
You shoud not measure any voltage across the coil with the engine not running since there is no current flowing through it. But both sides of the primary should measure 12 volts towards GND.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-21-2009, 10:00 PM
Senior Advisor
James Brown's Avatar
closest thing I have to "realistic" is my "zenith".......cool stuff, keep it up
08 Cayenne Turbo
Old 08-22-2009, 01:47 AM
I was wondering what the stuff in yellow did. To me, after some arduous calculations, I figure it limits the current to about 8 amps.
When you turn the ignition on is there a constant 8 amps going through the coil? (Before the engine runs)
EDIT: let me rephrase that. When you turn on the ignition does the DME wait for speed sensor inputs to charge the coil or is it always on?
Rick
88 Cab
Old 08-22-2009, 09:24 AM
ischmitz's Avatar
The coil is only charged for the dwell time when the DME receives a signal on the speed sensor input. Else the Darlington is off the and the coil isn't charged. So with the ignition ON but no cranking the coil isn't charged.
And yes, the yellow box is a current sense-driven current limiter. The 0.05 Ohm resistor measures the current.
Old 08-22-2009, 11:19 AM
So the guy in the other thread you can conclude his DME is Tango Uniform if he sees 4.5 volts across the coil primary.
The other thing I was trying to figure out is that network down and to the right of the yellow box. It is obviously a network to keep the Darlington from going into deep saturation but I haven't seen anything like that before.
When you change T504 what parameter do you look at to choose the Select In Test (SIT) resistor R517? At least I think Abgleichwiderstand translats to SIT.
I can see R526 and R508 (both have A on them) would be selected to adjust the current.
Rick
88 Cab
Old 08-22-2009, 12:39 PM
Wavey's Avatar
You guys are just making all this up, right?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 08-22-2009, 06:28 PM
Irrationally exuberant
ChrisBennet's Avatar
Years back a started/tried to make something similar only using a PIC processor to make the timing and reference signal. Hat's off to you!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-22-2009, 07:22 PM
ischmitz's Avatar
I have seen PIC-based solutions from the Megasquirt crowd before. Quite nice but I simply don't have the patience to learn programming for these little buggers. See here for a superb example: http://jbperf.com/JimStim/index.html that can actually be configured without programming skills.
It makes my signal generator look like a stone age tool in comparison.
I also used the sound card for a 60-2 wheel before but then I always needed the PC next to the tester. Cumbersome, but it worked. See here: http://www.megamanual.com/router/crankwheelpulser.htm
Old 08-23-2009, 11:26 PM
RETIRED
Joe Bob's Avatar
Smoke and mirrors.....he just does miracles.....
2012 ML350 3.0 Turbo Diesel
Old 08-24-2009, 01:42 AM
Checked out
McLovin's Avatar
LOL.
That creation is damn sweet.
The function is unbelievable, but I also like the retro/mad scientist look of the contraption!
Old 09-28-2009, 10:43 AM
