Banned
Is turn signal switch fixable ??
My turn signal switch has become "wobbly" with time, this means it jumps from low beam to hi beam whenever I hit a slight imperfection on the road or when I signal a turn.
Before shelling out some reasonable bucks for a new one, I would like to know if the old one can usually be fixed in some way, maybe a new spring ? Does anyone has done it before ??? |
This is a great question. I have a simular problem. I had to wiggle mine to get the low beams to stay on. Now that they are not working at all. There must be a way to rebuild them...
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Northern Motorhead
There are lots of posts on how to rebuild and repair... search for headlight /turn signal switch on this forum...
Although mine had the same problem,i waited too long and it was beyond repair when i took it apart. Pelican sells new switches !!!
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
What will happen is you will get the unit out of the car and find like I did, it is beyond redemption, just worn out. Then you order a new one from our host and wait a week or so of down time before you can have the part to install.
No sleep 'til... BROOKLYN
If that's all that's wrong with yours then you should try this, I just did it for mine, just 8 screws, can't get any easier. turn signal switch quick fix pictures Take care, ![]() O-
-Orlando- '89 3.2L G-50 '77 S w '79, 3.0L '90 T-3 Syncro 32C #16 |
yep "twice" and failed on each account. Once for the High Beam, and second on the Self Cancelling. Each time spent hours trying to get a permanent fix only to fail again a very short time afterwards. I ended the saga gladly parting with the $$$ for a new switch.
Cheers, Sean. 94 911 Carrera 2 993 Cab http://www.pelicanparts.com/gallery/Sean_Hamilton |
Get yourself a new one. It is PITA trying to repair the old one ask me why. Order wait and when you receive it install thats all I have to say about that.....
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
Only one problem. I replaced the original (1985) switch last year. Now the replacement is doing the same thing. Turn signal cancels, high beams come on.
I installed relays on the headlights at the same time that I replaced the dimmer switch fwiw.
Will 85 carrera |
Northern Motorhead
For what it's worth,go ahead and purchase a new one from Pelican... I bought a used one on this forum and the guy shipped it ten days after i had paid him and had the wrong street name on the mailing address so it took almost one month for me to get it...
All that to save $60.00 dollars off the cost of a new one .... For anybody attempting the replacement,do yourself a favor and remove the light switch as it is sooooo... much easier to change/connect the wires with the switch hanging below the front panel !!! Pry off the cover from the switch knob,remove jam nut with a 10mm deep socket and use a small screwdriver to unscrew the plastic "washer"and pop the switch out through the front panel !
I'm here to cause trouble
It's really an easy fix... clean out the built up crud, bend the connectors slightly as described. Mine did it for years until I found the fix on this forum. No problems since...
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
I bought a new one and installed the relays and it still does the high beam thing all the time.
Chris 73 911 E |
Information Junky
I had (and easily fixed) the problem --Search under John Walkers posts.
Here is one Headlight dimmer repair? Quote:
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
