Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Is turn signal switch fixable ??
My turn signal switch has become "wobbly" with time, this means it jumps from low beam to hi beam whenever I hit a slight imperfection on the road or when I signal a turn.
Before shelling out some reasonable bucks for a new one, I would like to know if the old one can usually be fixed in some way, maybe a new spring ?
Does anyone has done it before ???
Old 08-23-2009, 02:58 AM
austin552's Avatar
This is a great question. I have a simular problem. I had to wiggle mine to get the low beams to stay on. Now that they are not working at all. There must be a way to rebuild them...
1974 911s
Old 08-23-2009, 04:06 AM
Northern Motorhead
wildcat077's Avatar
There are lots of posts on how to rebuild and repair... search for headlight /turn signal switch on this forum...
Although mine had the same problem,i waited too long and it was beyond repair when i took it apart.
Pelican sells new switches !!!
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-23-2009, 04:42 AM
p911dad's Avatar
What will happen is you will get the unit out of the car and find like I did, it is beyond redemption, just worn out. Then you order a new one from our host and wait a week or so of down time before you can have the part to install.
Old 08-23-2009, 04:52 AM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
from prebordao
If that's all that's wrong with yours then you should try this, I just did it for mine, just 8 screws, can't get any easier.
turn signal switch quick fix pictures
Take care,
O-
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 08-23-2009, 05:10 AM
Sean Hamilton's Avatar
yep "twice" and failed on each account. Once for the High Beam, and second on the Self Cancelling. Each time spent hours trying to get a permanent fix only to fail again a very short time afterwards. I ended the saga gladly parting with the $$$ for a new switch.
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 08-23-2009, 08:46 AM
Daviboy's Avatar
Get yourself a new one. It is PITA trying to repair the old one ask me why. Order wait and when you receive it install thats all I have to say about that.....
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 08-23-2009, 09:12 AM
williecoyote's Avatar
Only one problem. I replaced the original (1985) switch last year. Now the replacement is doing the same thing. Turn signal cancels, high beams come on.
I installed relays on the headlights at the same time that I replaced the dimmer switch fwiw.
Will
85 carrera
Old 09-20-2009, 06:17 AM
Northern Motorhead
wildcat077's Avatar
For what it's worth,go ahead and purchase a new one from Pelican... I bought a used one on this forum and the guy shipped it ten days after i had paid him and had the wrong street name on the mailing address so it took almost one month for me to get it...
All that to save $60.00 dollars off the cost of a new one ....
For anybody attempting the replacement,do yourself a favor and remove the light switch
as it is sooooo... much easier to change/connect the wires with the switch hanging below the front panel !!! Pry off the cover from the switch knob,remove jam nut with a 10mm deep socket and use a small screwdriver to unscrew the plastic "washer"and pop the switch out through the front panel !
Cheers
Phil
Old 09-20-2009, 07:03 AM
I'm here to cause trouble
jimbauman's Avatar
It's really an easy fix... clean out the built up crud, bend the connectors slightly as described. Mine did it for years until I found the fix on this forum. No problems since...
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 09-20-2009, 07:21 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I bought a new one and installed the relays and it still does the high beam thing all the time.
Chris
73 911 E
Old 09-21-2009, 10:15 AM
Information Junky
island911's Avatar
I had (and easily fixed) the problem --Search under John Walkers posts.
Here is one Headlight dimmer repair?
Originally Posted by john walker's workshop View Post
the thicker metal bar above the thin brass strips needs to be bent very slightly toward the brass strips. support it's pivot point when you do the bending or it can pop out. the ends of the brass strips run in a plastic slider that tends to melt in place. if it's melted, replace the switch.
Originally Posted by HarryD View Post
Here's a picture from i_got_an_sc to help you out:
You can read the thread here: turn signal switch quick fix pictures
More info in HarryD's link above
Old 09-21-2009, 10:32 AM
