Louie: PM sent from me.
If you snip the green wire on the stock OEM harness be aware that it is a shielded wire. Be certain you do not somehow short the shield to the center conductor. I had a car where someone had tried to fix this wire and they soldered the shield to the center O2 signal line. It took over 2 days to figure this out and it totally screwed up the mixture since it tricked the DME into thinking the mixture was always lean and the end result was the DME trying to richen the mixture! What a pain to figure out this over rich condition!
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
I don't agree with this statement? You can solder if done properly. Also consider that within the DME the O2 sensor signal travels through several (10+) soldered connections without any issue, adding just one more will not change things. A soldered connection will be better than a mechanically connected terminal.
I agree with Sal, if you look closely at the end connector it's actually soldered.
91 964 Guards Red 64 356C Ruby Red 85 Carrera (Gone but not forgotten) |
Very nice job on this part. IMHO: I would simply wire this new part by:
1- cutting the stock OEM green wire. 2- Remove and discard the old connector. 3- Cut back the shield about 1/2" and shrink tube it. 4- Solder a round spade to the center black 'O2 Signal' line within the green wire. 5- Attach to new plug. Once again nice job.
Member 911 Anonymous
, I still love my BMW/Buick metal injectors take care, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
oxygen sensor
louie, i need one of those, i have a current thread running 3.2 won't start. One of the issues is a broke O sensor. you can send me your info to [ i'll send paypal or check
thanks mark
52 356 coupe 56 speedster 63 356 Cab? 69 911T 69 912 beater Last edited by marktodo; 04-18-2013 at 12:43 PM.. |
My son installed this piece on his 85 Carrera. Easy install and problems with running SOLVED.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
We just got it to run by pulling an injector plug and manually grounding it. It's definaty electrical
PM him. I don't think he's on here as often as some of us are!
'84 Carrera Cabriolet Last edited by BE911SC; 04-18-2013 at 12:50 PM.. |
Thanks Louie got back to me could you remove my email as i can't edit it
Thanks mark
52 356 coupe 56 speedster 63 356 Cab? 69 911T 69 912 beater |
Done.
'84 Carrera Cabriolet |
installing
Louis, i too seem dumb as a rock. It looks like the pictures puts yours in series with the old one. My old one is severed. the car is in the upholstry shop right now so I haven't been able to compare pictures on this thread to it yet.
mark
Mark,
You just need the most inner wire, the other is just shielding. Here's some information from Sal. Hope this help. Originally Posted by scarceller View Post Very nice job on this part. IMHO: I would simply wire this new part by: 1- cutting the stock OEM green wire. 2- Remove and discard the old connector. 3- Cut back the shield about 1/2" and shrink tube it. 4- Solder a round spade to the center black 'O2 Signal' line within the green wire. 5- Attach to new plug. Once again nice job.
Hi louise
Do you still have extra piece that I can buy from you? If yes then How much and How do I send you the payment? Thanks |
To be precise, the sensor needs a reference oxygen source, and the electrode is internally open to atmosphere on one side so it can obtain it. This oxygen actually travels down the braided copper connector wire. See p14: http://wbo2.com/lsu/oxygen13-17.pdf It certainly doesn't need much oxygen - but that's why anything that prevents or restricts free flow of oxygen along the wire to the sensor - like soldering and/or heatshrinking the connectors, or blobbing silicon on them for "weatherproofing" - is really not a spiffy idea. Bosch oxygen sensor installation document specifically states (second bolded bullet point on the first page) : Quote:
This part has been around since Bosch invented it in 1982. Still amazed this isn't common knowledge.
'77 S with '78 930 power and a few other things. |
I read the above documents. There are a number of reasons not to solder automotive wires in certain applications. If you look at their universal O2 sensor kit, they cut the wires and splice on the OE connector with Posi-lock connectors. These are very nice connectors.
Do you guys really think the O2 sensor sucks air in along the length of the wire for its reference material (like Fernando Valenzuela breathing through his eyes?) ? I think the air is exposed to the reference electrode at the sensor itself. I also think the solder comment is because soldering fine wires causes a fatigue issue which can lead to breakage when exposed to vibration. Posi-lock tolerate this much better. That's why they talk about early failure in the above document, not malfunction or inaccuracy. Anyway, that's how I understood it, and I may be completely wrong. Good luck, Dave Last edited by DaveMcKenz; 09-13-2014 at 11:52 AM.. |
Nice to see Bosch seem to have the same opinion. Quote:
Do a search on this forum (especially the 944 side) for FR Wilks. Don't know if he's posted recently, but used to be fairly active when I ran a 944 - long time ago now. Then read his website, and see if you think he knows what he's talking about. (guy has re-engineered and sells PROMs for the 944 Motronic, both for more power and the "shudder fix" that afflicts some ageing 944's - he owns several of these, heh). His website probably contains the most information freely available on the web for the Bosche Motronics and associated sensors. But it's 944-centric, although much of the information is applicable to other brands/models, naturally. Based on his instructions, I socketed a buddy's Series 1 944 (24 pin) Motoronic to 28 pin so we could use the Wilks shudder-fix PROM. Worked a treat, issue solved never to return (buddy was then sorry he'd not opted for the PowerPROM, but that's another story, heh). In my opinion, it's pretty obvious Mr. Wilks has been involved in embedded microcontroller applications for many years and knows his way around ICE's and disassemblers, as well as early automotive engine management systems. He says on his website, (copyright date of 1999) Oxygen Sensor - Lambda, right under the table of Bosch replacement part #'s: Quote:
OK. I stand corrected. I guess I was thinking aobut the older O2 sensors before special lambda wire was used.
Thanks for the information. Dave |
Will this fit an 82 SC?
1982 SC |
