<insert witty title here>
Christien's Avatar
Just installed WM front sway bar - questions
Installation went fine, in fact easier than expected. I set the adjustment as per the instructions, but I want to make sure I didn't really mess anything up:
1. front/back movement of the drop links doesn't seem very much - total adjustment would be maybe an inch, probably less, sliding along the vertical shaft. Is this right?
2. and may play into #1, I set it all up with the front up on jack stands. That's the way Wayne instructs in 101 Projects, but I read in a few places here on the board that the drop links should be set with the car on the ground.
I've got a track day on Monday when I'll do some fine-tuning, but I do need to make sure the car's at least safe in the meantime, as I plan on driving it over the weekend, including on the highway. Is it at all possible to screw up the installation badly enough as to make the car unsafe?
Thanks for indulging what may be some stupid questions
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-11-2009, 09:02 PM
Walt Fricke's Avatar
Since I gather you have adjustable drop links, you want to set those with the car on the ground. And someone or something simulating your weight in the driver's seat, if you want to go the extra mile here. Probably be OK without doing that.
However, no amount of screwing this up will make your car undriveable.
Walt Fricke
Old 09-12-2009, 12:12 AM
Christien's Avatar
Ok, thanks for clarifying!
Old 09-12-2009, 04:59 AM
tobluforu's Avatar
With car on ground, make sure there is no pre-load on the drop links. As a start, make sure the drop links are connected at the same length from the end of the bar, then go from there to fine tune.
Old 09-12-2009, 06:18 AM
Christien's Avatar
Ok, got it set to the default setup and had a nice long test drive. WOW, what a difference! Even without fine-tuning it at all, it feels so much better in corners. I've got a track day Monday where I can get it fine-tuned.
Old 09-12-2009, 12:07 PM
