Throw it on the ground!
Thanks guys!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
LOL, same on my 930, I only have to drive out of the garage into a foggy day, that's it
Roland 930 Turbo '81 Too many modifications to list |
I have a 86 3.2 also and ive been getting fog also in the oil pressure, oil temp, and tachometer........I live in atlanta also ............hmmmm
Can anyone say foggy gauge government conspiracy? hahah
cycling has-been
anyone had any luck by sending the gauges out to Palo Alto or Hollywood to be resealed?
I bought a few replacement gauges and was going to send my oem's out for rehab. not a problem on my 73 (115,000 miles), but pops up on my 77 all the time (102,000) Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 09-23-2009 at 06:56 AM.. |
Just to add another twist to the saga,
I have a 914 resto that I put a full 911 dash into and the the car has not seen the "outdoor light of day" yet and little lone even been wet. 911 Dash The gas/oil gauge fogs up after starting the engine and running a while. None of the other gauges do this. Is it possible that the gauge movement coils have some moisture in them and when running they slightly warm up and release the moisture?
My car does this as well.
Here's my guess. The air inside the gauge is roughly the same humidity as the ambient air. As the engine warms up, the air pasing through the heating ducts behind the left side of the dash heats up, which starts to heat up the left side gauge. When this happens, the glass face is the coolest part of the gauge and the moisture from the air inside the gauge condenses there. The left side is more prone to this because the left side of the dash is closest to the heat ducts. The guage is nearly (but not quite) air-tight and the air is stagnant inside so it take a long time to equilibrate with the outside air. Just a thought....
Steve B. 1972 911t 1999 328is |
My 964T does this as well. Its my fuel gauge. I took it all apart, as it was on the inside. After carefully prying the ring apart and removing it, I discovered that it is actually the glass de-laminating in between.
My SC is kept inside an air conditioned garage and its heated in the winter. The car does not get driven in the rain and I ca not remember the car getting wet in the last five years. I have never taken it to a high pressure wash. I took it out last week and one of my gauges fogged. I figured it was becasue it was nice an cool inside then I took it out in the heat.
Aw, just fog it and live with it! Happy autumn everyone!
proffighter-
Yeah, I agree. I just pulled the gauge and looked behind it and there isn't a heating duct anywhere near it, so I am officially stupid. I knew I should have looked before I posted. It is funny that my car has been on stands in the garage for a year and the gauge is STILL fogged up!
Hey there, I have the same issue on my '81 SC. How did you remove the gauges? Do you think it's worth it? Thanks! James |
I put a small desiccant pack (the kind that comes in a pill bottle) inside my gauges and it fixed the problem.
Add mine to the list. 89 3.2 is never driven in the rain but sits in a garage that is cooler or warmer depending on the weather. I believe it is the humidity causing the condensation. Only the far left gauge fogs and that is one of the three that was sent out and rebuilt by one of the speedo rebuild companies. My guess is that the seal is leaking and moisture (humidity)is getting in. I can live with it, at least it is not the tach or speedo. Steve
Steve 1970 911T SOLD 1989 3.2 Carrera 2013 991 Carrera S |
My oil pressure gauge has done the same thing I discovered that when it occurred that it was the only gauge in the dash that was warm probably the defrost duct heating it cold dense air plus warm air equals condensation if we all have the same gauge doing it and it hasn't been raining that's my guess
1979 911sc
Add my 79sc to the list... Along with smoke on startup, moderate heat in winter etc...
1979 911sc 1969 Rover 2000 TC 2000 Ford Excursion 2015 Ford Transit 350 |
Member 911 Anonymous
Fellas, foggy gauges is not normal.
The culprits: Loose Wiper Nozzles Loose Wipers Clogged or dislodged fresh air intake scoop or drain Windshield Seal I had issues with a drip on my passenger side, drove me crazy. I was detailing my car and noticed my nozzles and wipers were loose. sealed nozzles and tighened the wipers. Tested no more leaks. The one night I decided to work on my AC. I went in for dinner and turned my garage light off and left the hand light on. To my amazement I saw pin hole lights coming from my trunk into the cab area under the dash. Sealed all pin holes. No more leaks j
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Don't any of you have the anti-fog pump? Mine, I thought they all were, is mounted just behind the brake fluid reservoir on my 74. Tiny rubber lines are routed to each gauge. If these rot, or are carelessly knocked off, or even eaten by rodents you will have no end of trouble. Lose one line and get one foggy gauge. McMaster in LA sells the rubber tubing, N.H. Speedometer and others can rebuild the very tiny pumps.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Mine did this as well.
I got some 'rockwool' house insulation and packed it behind the instruments. Doesn't do it anymore. |
