help needed identifying transmission
I was wanting to know if someone could help me identify a porsche 901 transmission. The numbers are 911/01 and 7119102. I need to know if it is alum. or mag? 4 speed or 5? what year the transaxle is? and what model car did it come out of? Thanks so much for your help.
bajabugman,
7119102 7 = Transmission designation, Transmission for 6-cylinder engine. 1 = Transmission type 911/01, 5-speed, standard ratio. 1 = Model year 1971. 9102 = sequential number. Type 911/01: 1st gear = 11:34 2nd gear = 18:32 3rd gear = 23:28 4th gear = 27:25 5th gear = 29:22 R&P = 7:31 This is a Type 911 transmission although many 901 parts are common. Simplified differential Magnesium castings 225 mm pull-type clutch 108 mm CV joint flanges Does this have the numbers on a rectangular boss cast under the differential or on the longitudinal rib? Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thread Tools | |
Rate This Thread | |
