side marker delete = fast turn signals
Hi All,
After deleting my side markers, my turn signals flash fast, as the relay thinks a bulb is blown.
Is there any solution for this other than adding resistors into the system?
Thanks,
Adam
_____________________
'73 RSR Interpretation
Old 12-03-2009, 05:44 AM
sudo apt-get purge 930
equality72521's Avatar
Not that I know of, I would just add resistors and be done with it.
--clutch-monkey
Old 12-03-2009, 06:08 AM
Formerly known as Syzygy
Canada Kev's Avatar
Or an electronic flasher. There's just not enough electrical load to flash at the correct speed. The same thing happens with LED lights.
Kevin
Old 12-03-2009, 08:36 AM
scotricker's Avatar
my turn signals flash fast all the time, too. I've never had side marker lights.
I just thought that's the way this car was made. Or do I need to fix something , too? All the bulbs are good.
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 12-03-2009, 10:54 AM
Senior Advisor
James Brown's Avatar
The problem is you guys have the Japanese-type flasher and you need the ROW type flasher installed. The Japan flashers are real popular with the tuner crowd and they go for a premium so don't throw them out (can't remember the p/n). Just make sure that you ask for the ROW type flasher when ordering.
08 Cayenne Turbo
Old 12-03-2009, 11:20 AM
Resistors are cheap...
--clutch-monkey
Old 12-03-2009, 01:31 PM
i've got an electronic flasher that is designed for LEDs, but its max load is 20A.
So i'm thinking it would burn out with normal bulbs.
I have R lights, so i think each of those indicators are 8A. I think the front turn signals are 10A each.
Old 12-03-2009, 03:08 PM
Canada Kev's Avatar
10A is quite a lot. What's the fuse for that cct?
Kevin
Old 12-03-2009, 05:08 PM
sorry... i realised i meant watts, not amps.
So amps = wattage/ voltage
i know the rear R light bulbs are 18W each. I vaguely remember the front bulbs being 21W. Need to check that.
But if that's the case, my setup will draw only 6.5amps. I'll have to check this, but sounds promising =D
Old 12-03-2009, 08:49 PM
Porsche Owner
mark4ton's Avatar
okay so has someone fixed the fast blinking problem? i bought the side marker deletes and would like to plan ahead on installing them. if anyone can do a step by step walk through thatd be nice. thanks.
1987 Carrera - 2008 Cayenne Turbo
Old 01-29-2011, 08:38 PM
Carrera Cab Connoisseur
nyne11's Avatar
Try increasing wattage of both front and rear to compensate for the side marker delete.
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 01-29-2011, 09:38 PM
UnRegistered User
billybek's Avatar
You might want to watch the plastic inside and outside the light housing if you increase the wattage. More watts = more heat = melted plastic.
Bill K.
Old 01-30-2011, 06:00 AM
Danny_Ocean's Avatar
I doubt turn signals will stay illuminated long enough to build up enough heat to melt plastic.
Those with the fast-flasher problem need to change your flasher relay:
Electronic LED Blinker Flasher Relay Fix Turn Signal - eBay (item 220723739927 end time Feb-10-11 07:56:28 PST)
Note: This relay might not be the correct piece for your application. You need to see which relay replaces your existing relay.
Old 01-30-2011, 06:07 AM
