Senior Advisor
Oil weight discussions pail in comparison to ZDDP content in your oil. Your required reading lesson is this, read the engine oil thread on this forum, then report back to us what oil you will be running. we can TELL you but if you read it, you will understand so much more about oil than you thought you ever would, good luck/
08 Cayenne Turbo |
But the main reason is that M1 0W-40 has less zinc and phosphorous: Phosphorus - 1000 PPM Zinc - 1100 Now, those aren't bad numbers, but still. If you get a little more in 15W-50 for the same money, I'd take it! It's supposed to make a difference, and it's the recommendation from Mobil themselves for "flat tappet" applications (that's us). |
I've decided to go with an old $3.99 case of Pennzoil I found in the back of a Circle K. I'll be reporting back within the next 5000-15000 miles on it's much expected performance qualities. Something tells me this is the stuff. Sean Pitt (Brad Penn?) motor oils look out.
Now in 993 land ...
Another thought is that you may need a new rubber seal in the rear window earlier than later. If this is the case, you may want to remove the tint while the window is out. This would be a very good time. Indeed, IIRC the heater element is bonded on from the inside. They are metal traces, not round wires, but you will not be able to go at it with a blade / spatula without possibly hurting these. George |
Removing tint
I followed the instructions on this page for removing the tint on my 928. Around the defroster wires I used a plastic scraper like an old credit card on a hot day with plenty of Windex on it. If it is sticking too well on a wire, spray and soak until it softens.
http://www.tintdude.com/remove.html
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
