Hi All,
Could someone give me the dimension for the factory placement of the Carrera script for the 84 to 89 Carreras? I had my rear deck lid resprayed and am unsure of how far below the grill it is supposed to be placed. Steve |
Happened to me.
I put mine smack in the middle, the factory location is 3/4 of the way up to the grill. |
Friend of Warren
Here's a pic for you to look at:
Kurt V No more Porsches, but a revolving number of motorcycles. |
I'll add mine, a bit closer - I can measure tonight if necessary
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
The measurement is exactly 7 5/8 using a flexible tape measure following the contours from the edge of the lid to the bottom of the script as shown. Use some dry erase markers and then find the center
script height
Didn't all cars with the factory tail have the script mounted lower than the non-tail adorned examples? For example, have you ever seen a Carrera with a tail added later and noticed that the script "Carrera" seemed to be too close to the bottom of the tail mount. I submit there are two heights.
I had thought the same thing about the rear wings and the script. Was saving this question for when I got home but I'll take an anwswer now
rj cilurso 87 911 targa 05 Vette |
Thanks guys for all your replies.
89911, I measured 7 5/8 from the bottom edge as you specified, but it seemed a bit low - some of the pictures show it being 3-4" higher. Does your car have a tail - seems like it from your pic? My car doesn't have a tail. I would like to place the script where it was originally - my bad for not taking measurements before removing it. I am still looking for the alternate measurement where it is placed 3/4 of the way up to the grill. KurtV, steve911 what are the measurements of your scripts? Thanks. Steve Last edited by Steve W; 11-15-2001 at 10:52 AM.. |
Friend of Warren
That's it Steve, give me any excuse to go outside in this beautiful (73 degrees) fall day in Missouri to go look at my car.
A guy in my neighborhood has an '85 Carrera with a factory Carrera tail. The car is original, and the script is indeed mounted lower than that of a car without a tail.......
Michael '98 Boxster in Ocean Jade Metallic |
Kurt -
Thanks - that's the exact dimension I needed. I hope you didn't too overwhelmed by your weather there. Again everyone, thanks for your help. Steve |
It's just tacked on and can be changed easily. Put it at an angle, upside down, try it around. Have some fun, then decide where you want it.
It's not a Corvette, you don't need to have it perfect. ![]() ![]() ![]() Last edited by Mrdi; 11-15-2001 at 02:21 PM.. |
911 user
Why not leave it off if it's not a concours contestant? It would make washing and polishing a lot easier.
Thread Tools | |
Rate This Thread | |
