Basic 3.2 Performace Tips
I am considering injecting HP into my stock 87 Carrera Cab/G50 3.2 moving up to the SW Chip, K&N, exhaust, muffler and cam for starters. Which camshafts are the HP upgrade for the 3.2L, the 964 or 993? What mods need to happen once cams are updated? I've read somewhere the drive on the cam is somewhat different from the stock cam, comments? Which exhaust w/flipped flanges, 964 or 993? Finally, if you have an SW chip, are you able to send it back to SW for reprogramming if your config changes? Thanks for your tech tips!!
For starters, you can forget about installing a K&N...All they do is introduce more dirt. Do a search
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
964 cams have the ps drive on the end of the camshaft. You can either cut it off or get the plate to accept it. I still don't know about all the bad rap K&N gets. Other than people not knowing how to wash and oil them.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Opinions vary. Had one on mine for 45K miles, and the AFM and TB are as clean as a whistle.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Jupiter 911
I still run a K&N on my 87 Targa but I do have proof it destroyed the air sensor on my wifes 2002 Boxster. That being said the answer to your SW chip is yes, I had sent my back twice to be re-calibrated when I relized the po had put in up grades. Enjoy.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
just me
ok, here is what I have done with my opinion only on how they affected performance.
K&N filter. no difference compared to stock. Cutting holes in the air filter cover. no difference but sounds faster... lol putting all new sensors in for flywheel and cylinder head temp. huge difference in driveability which is just as important as power if you ask me. new fuel relay does wonders as well. make sure your engine runs right before you try to make it faster! Catalytic converter bypass on stock heat exchangers. sounds better and felt freer revving SW chip for stock exhaust. HUGE do it now! flow test and rebuild injectors. another big step in the right direction. goes back to getting everything in good condition before trying to make it faster. rebuild of tired engine with worn valve guides and piston rings. feels like a new engine! SSI's and M&K 2 in 1 out muffler and SW 93 octane chip to match. holy crap! cams will move the peak torque and power around unless you start to do serious interior engine mods to benefit them. unless I am mistaken. next for me might be to bore out the intake not sure if it is necessary though.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Right, it's possible for them to oil the wire-type air sensor. The subject Motronic cars have a different AFM.
It would be interesting to see some dyno results for the various changes.
just me
Steve Wong has a bunch of dyno results for 3.2l engines in different states of modification
I was going to change to SSI and M&K exhaust with a extrude hone intake and SW chip but....will this need to be combined with a cam change (964) to really see improvements?
For air filter infor look here Air Filter Filtration Test This site should be required reading before you buy. Last edited by DG624; 10-21-2010 at 04:06 PM.. |
Most times, suspension upgrades, brakes, and lightening the car are the most significant mods that result in better lap times. Unless of course, you are only looking to go fast in a straight line. Either way, bring your check book.
I have reduced weight by 200 lbs and improved the torsion bar rate and the shocks. I would like to upgrade the sway bars and put in some chassis reinforcement. The car should be faster but I also wanted to get some basic power improvements also.
I have owned a 3.2 Carrera for something like 3 years this month (hard to believe I've had it that long). I've been reading everything "Carrera" that pops up here for that length of time.
The consensus is that the exhaust is definitely constipated. Crawl under there and tell me it doesn't look constipated. I'd put any money in the tune up mentioned, a much freer exhaust (flipped 993 exchangers have looked the best to me) and a Wong chip to match. Next would be Euro pistons and then maybe a bored out throttle body. I guess the 964 cams are a given if the heads come off and the pistons are replaced. Some mild porting of the heads would be nice, but I don't think you'd gain all that much keeping the Motronic fuel injection. Every little bit helps, but people report the biggest gain by losing the stock cross over exhaust. |
abit off center
lose weight!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Now in 993 land ...
My recommendation for more power is a cat bypass if you live in a place where smog isn't an issue, 964 cams and a SW chip custom programmed for this set up. If you do this work yourself, it is a cost effective hp gain. If yo upay someone, the cams may have to wait until you have the engine out / heads off anyway. K&N filters IMHO are fine in terms of filtration. I have had them and the oil analysis would always come back clean on air filtration. They are not really adding a lot of power though, if any - the Porsche air filters have a huge area and really don't restrict flow. George |
Large Registered Member
Most cost effective HP gain IMHO, Cat bypass, free flow muffler (Dynomax/Flowmaster/Magnaflo/Bursch) and a custom mapped chip from Steve Wong. (911chips.com) You might see 30hp gains right there, plus better low end driveability and big MPG improvement!... Of course you will see even more gains with a 964 cam, and extrude hone, but the price tag really starts climbing with the last 2! Headers help as well, but you lose the heater.
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Green Skull 006
You can use B&B headers and still have heat.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
Schleprock
Agreed the most important thing is to first ensure your engine is in proper operating condition to begin with.
>Fresh fuel and air filters. I'd vote for the paper filter. Cheap and flows plenty >Plugs and O2 sensor should be fairly fresh. Don't get crazy with plug choices. Basic Bosch or NGK coppers are perfectly fine. >Agreed the head temp sensor should be checked. One wire sensor is known to cause driveability problems. >Reference sensors are not a driveability problem. They're an on-off sort of effect. >Check that your throttle linkage is properly adjusted. You'd be surprised how many people find they're not getting full throttle. This is important because the full throttle switch can't be activated if you're not getting full throttle! >Run some good cleaner thru the fuel system. You'd be surprised by how much carbon buildup can be on some engine's valves- especially exhaust. My favorite is Berryman B12 Chemtool. Cleaned up my valves in one tankful. >Agreed the injectors are not always flowing at their best and even a fuel treatment doesn't fully fix that. That's just maintenance-type stuff. Performance? >Exhaust i'd recommend a good muffler and dump the cat. The factory exhaust system isn't optimum, but it does OK. >Cams i'd recommend 964 (like George said, no need to buy actual 964, just get yours reground to 964 profile) and that's all unless you're willing to change the pistons. The factory "smog" smushed top pistons don't let more aggressive cams do their thing. >For a G50, i'd recommend getting a lighter clutch. The factory clutch is a boat anchor. 3.2 throttle response is fairly lethargic, so the lighter clutch helps. Those who have a chip upgrade will tell you that it makes the response lightning quick, but it's still rather slow compared to a more effective injection system like individual throttle bodies or carbs. >Chip is a wise move. Steve Wong's 911 chips are great and his support is excellent as well. Make sure you look at some reliability upgrades too. >How old are the chain tensioners? >How are the valve guides? >Consider having your air flow meter refurbished/checked for good sweep on the contact surface Lastly, yep, lightening is the cheapest HP you can get. All depends on how much you're willing to sacrifice. Do a search for ShakinJoe "438 lbs gone" and you'll see how far he took it. His is an extreme case of street-to-track transformation, so i'm not suggesting that's what you have to do. Point being is Joe did a great job documenting how much weight you lose from each deletion, and in some cases the replacement weight with new part. So you can pick and choose what you want to do, based on the net gains. The general rule of thumb is 10 lbs = 1 hp. Lose 100 and you gain around 10. Obviously you're not putting hp into the engine, just relieving the load on it. Still, the effects of weight loss are real w/out question.
Kevin L '86 Carrera "Larry" Last edited by KTL; 10-22-2010 at 06:39 AM.. |
Formerly known as Syzygy
Or those from Rarelyl8. They have heat exchangers that can be added. I haven't seen anyone that has used them, but there must be someone around here...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
