just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
I have driven my 9 in all kinds of nasty rain. I actually was very suprised by how well it handled the rain. how are your tires?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 02-19-2010, 08:52 PM
Ok, enough about the car... Where are the pictures of you date???
Old 02-19-2010, 08:55 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
15 M.P.H. I don't think so i put a car back together that hit a guard rail at 40ish and it was no where near as bad as your car is. im thinking that car is more of a parts car by the looks of the door alignment.
im thinking you should buy a C4 less likely to spin out.
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-19-2010, 09:26 PM
Registered Usurper
DARISC's Avatar
Originally Posted by WolfeMacleod View Post
That wheel's a Fuchs knock-off (forged rims bend, cast rims break off in chunks), right?
'82 SC RoW coupe
Old 02-19-2010, 09:39 PM
khamul02's Avatar
Dude, glad you are OK.. One the Rain note.. I drove my car in the heart of Katrina!!! Hydroplaned here and there but kept it under control with some pilots on the car.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-19-2010, 10:17 PM
Registered Usurper
DARISC's Avatar
Think about it; it rains a lot in Germany, the Porsche is German and is designed, built and tested on Germany's roads - both wet and dry. A 911 is as safe as and handles as well or better in the wet than any other car...if it's driven properly.
Sure, the rear weight bias provides for the dreaded pendulum effect that makes the car swap ends if one doesn't understand its dynamics and errs in judgement, and that pendulum effect happens more abruptly and at lower speeds in the wet, but the car is equally capable on wet and dry roads when driven by a capable driver.
I'm in SoCal, it doesn't rain much, but I love driving my SC in it when it does (but I'm also terrified of the idiots out there with me who haven't a clue about how to drive in the wet).
It's a poor craftsman who blames his tools.
'82 SC RoW coupe
Old 02-19-2010, 10:55 PM
Packy's Avatar
Believe me, I am in no way denying the fact that it was my fault. I loved the car and had a hell of a week and a half thinking about the accident. There could be many reasons why I f*cked this one up -2nd gear, 5500rpms, wet road, too much throttle on a turn, trying to show off, driving in the rain. My tires are okay, probably about 50% tread. I actually stayed on the throttle when it started to lose grip but when I got too close to the guard rail on the right I hit the brakes and it was all over. We didn't hit the guard rail but swerved pretty hard left and hit the dirt/rock wall then pulled a 180 and hit the big butt booty. One thing I keep going over in my mind was not putting the clutch in when I hit the brakes. The engine runs fine but I hope I have no valve damage from rolling backwards after we pulled a 180. I am 99% sure of no engine damage but I am going to check the valves and probably drop the engine just in case.
By the way, I know the physics very well of these cars and how they drive. I just made a mistake.
I was thinking of naming her after Britney Spears. She use to have a body every man wanted to be inside of but now she is trash. HA! I need a Britney sticker like the ones they have on the side of old war planes.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 02-19-2010, 11:17 PM
pwd72s's Avatar
My first impulse was to write something sarcastic...but naw...poor Packy feels bad enough.
Old 02-19-2010, 11:38 PM
a.k.a. G-man
Geronimo '74's Avatar
You should drive more safely.
In the rain, with a passenger, 2nd gear, 5500RPM, in a turn, WTF were you thinking??
That girl must like you A LOT! Enough to continue the date after you gave her a back-injury...
Don't take this the wrong way but if I had to guess your age after reading this, I would say you're about 17....
On the other hand, we've all F-ed up in some way or another.
Hopefully your girl recovers swiftly, back injuries can linger for a long time.
I hope the bruise on your ego will remind you to be more careful next time...
(And I'm sorry about the car, I hope you feel an appropriate amount of guilt and get her fixed)
Old 02-20-2010, 01:01 AM
Driver
Noah930's Avatar
Christ. 5500 rpm in 2nd gear. I think my car (assuming no wheelspin) would be doing about 60-70 mph! 15 mph is trundling through a parking lot just above idle.
Hope the girl turns out fine.
OP's not Russian by any chance...?
1990 Black 964 C2 Targa
Old 02-20-2010, 02:22 AM
I am happy you are reflecting on this. It is wrong to drive that recklessly on the street and it was lucky that no other cars were involved.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-20-2010, 02:25 AM
lateapex911's Avatar
TTIWWOP
Of the girl!
Oh, get out and do some DEs. Never hurts. And TREAD on the tires is EVERYthing...
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 02-20-2010, 02:58 AM
I did a DE at Lime Rock Park this past August. The last session was in the rain. A great way of learning the cars, & your capabilities in a controlled environment.
Glad you and your date are safe.
O2 In Sully We Believe
Old 02-20-2010, 04:41 AM
70SWT's Avatar
Originally Posted by Packy View Post
I know. I'll never drive a porsche in the rain again, I think that was the first mistake leading to this result. I hope everyone else can learn from this too. It gives me a whole new respect for those dirt rally drivers.
I don't understand this statement at all. We all have had a fender bender at some point. That doesn't mean you give up driving Porsches in the rain or any other particular weather situation - learn to drive them in all types of conditions, and drive within the limitations of your ability, the environment and the car you're in.
Old 02-20-2010, 07:08 AM
just me
paulgtr's Avatar
never drive faster than your guardian angel can fly!
Old 02-20-2010, 07:43 AM
Used Up User
imcarthur's Avatar
Words of wisdom.
Ian
'87 Carrera Cab
Old 02-20-2010, 07:51 AM
Nope, it's authentic. And, the wheel that came from the factory, too...
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 02-20-2010, 08:39 AM
A few years ago near Hell Michigan a guy in a 996 was showing off for a new gal in the car. Neither one made it out of the turn alive.
Keep it safe.
Old 02-20-2010, 09:00 AM
Driver
Noah930's Avatar
Having been on some Pelican drives, there are some out there who know some pretty fast angels.
Old 02-20-2010, 09:04 AM
just me
paulgtr's Avatar
I can just imagine. but those canyon roads are pretty desolate right? not a lot of intersections I hope. that is my fear. can't wait to do my first DE day in april at lime rock. have never felt like I could really drive my car as it should be on the roads. just not prudent
Old 02-20-2010, 09:14 AM
Tags
911sc , accident , oops , totalled
