group911@aol.co's Avatar
Originally Posted by proffighter View Post
No pics, but maybe helpful:
Can anyone decipher the difference between 91151201007 and 91151201900 ?
Also, Roland could you email me a copy of the document?
Thanks,
Bob
Thanks,
Bob
group911@aol.com
Old 12-06-2010, 06:50 AM
proffighter's Avatar
Thanks,
Bob
007 is glass fibre, 900 is polyurethane foam
email sent
Roland
930 Turbo '81 Too many modifications to list
Old 12-06-2010, 11:42 PM
Can any people that have second grill oening 1975 - 77 Fiberglass with metal inserts whaletails start checking this spot for part numbers.
Since this NON 2nd grill unit has the proper 911.512.010.07.
I would think the second grill units would have 930.512.010.01 (the same number is listed for both A/C (large 2nd grill) , and NON - A/C (small 2nd grill) in the PET. So I don't know what to say about that as they are 2 differant parts.
Anyway, like to see if anything is there at all.
Here's a glared from flash photo of the 911.512.010.07 stamping (you can get the gist) :
And if it's not in that spot , can you look around the tails hard. The 930 part number units had to be stamped somewhere , just as the 911 part number units seem to be.
Can people who have these (non 2nd grill) check for stampings also. And if you find a part number stamped , also report the single digit AFTER the triangle logo.
Thank you all in advance.
Old 01-25-2011, 03:48 PM
peon77's Avatar
RatBox, you and I are on the same wavelength. I saw allot of good info on this For sale ad
FS: Factory early carrera/turbo tail
It got me thinking about this thread again. I went and dug my 2 grill tail out of the shed and here are the pics.
Its all fiberglass it is about 1/3 the weight of the steel framed ones.
It does have a second grill with out any ducting. The grill is fastened by 3 pieces of metal that clamp the grill to the tail.
The part no is on the center piece by the latch it is 930 512 010.01 and nearly imposible to photograph. There is no digit after the P triangle.
75 911s
86 951 sold to make room for baby seat
09 335i 6MT
NVH
Old 01-25-2011, 03:59 PM
Peon
Your link goes to the wrong place.
I'll check some of my tails for numbers.
Thanks,
Bob
group911@aol.com
Old 01-25-2011, 06:09 PM
Neat peon77 ,
Another version I have not seen before.
But now this brings up a new issue (or more acurately , an issue that has been brewing) . Why is your version stamped with the 930 part number . But J. Schaefers (which is basically the same unit , both with 2nd opening) stamped with the 911 number ?
Mystifying isn't it. It seems Porsche did not really keep a good cataloging by part number of differant variations. Not only are units that are clearly differant , marked with the same number . Units that are basically the same can then be marked with differant numbers also.
Either it's disorganisation with cataloging / numbering whaletails....... OR , the digit I pointed out after the Porsche logo (yes , that is a fancy "P" in the triangle , this is a Porsche Logo) is the mark , or lack of , differentiating them.
Notice these three tails all have a different last Digit ?
V , K , or nothing .
I know one thing for certain , that digit means something........at least where it is present.
If it did not mean anything . It would not exist ( be there ) on some.
Old 01-25-2011, 06:35 PM
Cobalt's Avatar
Originally Posted by RatBox View Post
Neat peon77 ,
Just speculation but is it possible that Porsche made the first production run off of stock deck lids until proper tooling was made up and a part number assigned.
The tail i have for the 94 turbo S is verified as a factory part and it along with all of the shrouds do not have any part numbers. I would assume this was done since so few were made and were made by the exclusive department. The only marking on the entire tail is the same one that appears after the 7 on the picture above. although this was pressed into fiberglass resin. here are pictures of my tail which has never been painted and a factory turbo S tail painted black.
This last picture is of the shroud which has no markings at all but is identical to the piece used on a friends turbo S.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 01-26-2011, 06:29 AM
mycarrera2.7rs's Avatar
[QUOTE=mycarrera2.7rs;5711279]
Originally Posted by John Schaefer View Post
This is an aluminum and fiberglass tail that passed thru my hands not too long ago. I was told it was correct for an IROC w/o the ducktail. It was sold and now installed on a real IROC car
should anyone need it I have the small factory grille to fit the opening
for those interested I have now found the little grille,
it is a factory look part, not a cut down version but I could not find a part number,
I got it with a lot of parts from a 1976 Euro Carrera with factory 2.7 RS engine installed which is currently for sale on Pelican for $ 175k.?????????????
Anyway here are some pictures with dimensions should anyone need it:
1973.5 911T Coupe yellow
'02 Carrera Coupe C4S Black
Old 01-26-2011, 09:05 AM
Early small second grill tail. 930 512 010 01 . .
Thanks,
Bob
group911@aol.com
Old 01-26-2011, 05:01 PM
where is the number on the part?
could you show a further away shot with a circle where the # is?
and are you sure of the number as it looks different from what you have writen
as it looks like xxx 542 015 013???????????
thanks
JP
Old 01-26-2011, 06:34 PM
It's on the hood pin metal like the ones above.
I see what you mean on the numbers but I wrote it down when I took the pic and it's consistent with the other numbers.
Also, after the Porsche triangle, there are no letters.
Thanks,
Bob
group911@aol.com
Old 01-26-2011, 06:44 PM
Hello all,
Can someone check a 1975-77 930 A/C optioned whaletail (largest possible 2nd grill ) for a stamped part number in the groove of the cut off stub center support ?
Please post photo if you can. Or a least report , if you cannot get a photo happening. Please also note , if there is a digit stamped following the logo triangle.
Thx.
By the by , I'm looking for a metal shield like this . If anyone can help me out , PM me .
**Note - must be this version :
NOT this one :
Old 02-08-2011, 11:41 AM
Canyon Runner
70SC's Avatar
75 Carrera Tail
mine came with this tail on it . No #'s No Bumpers. All Fb- Glass. Pretty good fit. Very lite .Any idea's Original / Aftermarket ?Whose product ?
Glass looks to be in sheet form, with some loose areas
Old 02-08-2011, 03:20 PM
giovanni86's Avatar
what about this?
Old 02-08-2011, 03:34 PM
peon77's Avatar
Can you post some pics from the bottom side?
75 911s
09 335i 6MT
NVH
Old 02-08-2011, 03:40 PM
giovanni86's Avatar
mmmm
not at the moment... I will post pics as soon as possiblr
It has been coloured in white and the little opening has been closed...
is all fiberglass
I think it is not an original spoiler (I bought it for few money)
It comes from a 76 911s
Old 02-08-2011, 04:07 PM
giovanni86's Avatar
what you think about?
One more request.
If someone has a whaletail, which is a known original from a 1980 wiessach. Could you take some underside photos , with the shield removed ? And also check in the center support for a stamped part number , and possible following digit after the triangle ?
And post.
I would really like to examine one , for any possible differances between it and an earlier constucted non - 2nd grill unit. As I would believe some had to have been constructed in 1979.
I seriously doubt the factory had 400 units in reserve.
Old 02-08-2011, 05:07 PM
golfbuddah's Avatar
Hey,
I have one of those aftermarket 1994 turbo s tails. I was unsure what it was untill I read this thread.
Frank
Old 02-08-2011, 05:45 PM
golfbuddah's Avatar
pics
Old 02-08-2011, 05:48 PM
