Senior Member
Wolfe...........over the years, I have ignored John's advice two times. It was a mistake both times. He's been working on these cars exclusively for something like 30 years, and has forgotten more about them that I will ever know. He's giving you advice that will save you money and aggravation. I'm just sayin'.........
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Max Sluiter
So, can I get half credit since I knew something about diodes and rectifying the alternator's alternating voltage current output?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
The DME isn't going to like the input voltage it sees either. Some of the spikes may exceed the voltage ratings of the parts in the box and let the magic smoke out.
Rick 88 Cab |
![]() there are 6 diodes, 3 pairs, 1 pair for each of the 3 phases. you get the smiley above and an E for effort. there are some nice parting gifts for those that did not win.
Alps Adventurer
![]() There is no need for the e after the Ü if you are using a character with the umlauts.
Max Sluiter
oops, I forgot to take that out when I was editing the sig. Finally found how to type the umlauts. I'll fix that. Thanks.
I know the words do not form a coherent thought but I thought it looked a little better to eyes in the USA than alternatives.
17 if you count the module for the regulator. inside the regulator ????
Rick 88 Cab |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
