simple pedal cluster question
I want to adjust the accelerator (gas) pedal linkage and don't want to hurt the wooden panel in front of the pedal cluster. Is there a right way to remove it?
There is one nut holding it in place, at the bottom. At the top, there are 2 slotted holes that go over metal u shaped pieces. You will need to remove the gas pedal linkage form the pedal to remove the board.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Thanks!
Removing the rubber pads on the brake and clutch pedals will help to allow the pedals to pass thru the holes in the floor board.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
+1
