donnmaddy
Driver side door lock not working. Please help
88 911 Cab. My Central door locking system and my driver side door lock stopped working today. I can not push door lock down from inside or lock or unlock from out side, and also blew the central locking system fuse. My question is once I remove door panel, what should I look for once I get the panel off, also does the round door knob just pull off? By the way, would any of you Cab. owners be interested in a cheap and good idea I came up with for a wind screen. Thanks Don
The round door knob has a small cap covering a phillips screw.
Use something thin to pry the cap to prevent hurting its edge. Once the screw is removed, the center knurled round part (knob) can be removed. The door knob escutcheon must then be unscrewed off. Can't answer the power lock issue.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Recreational User
Before going through the trouble of removing your door panel, I would focus on determining why the fuse blew. After replacing it, does the passenger side door lock work normally?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
French Import
Also tell us where you are located, so maybe a local pelican can lend you a helping hand. You also need to post pics of your car (that should be mandatory! ).
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
