GaryR's Avatar
Send a message via ICQ to GaryR
For you oil fanatics ...
ZDDPlus - ZDDP Oil Additive for Classic Cars
Gary R.
Old 04-01-2010, 01:25 PM
careful with that stuff...too much is worse than too little! It is OK to use but follow directions and do not add too much.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 04-01-2010, 02:20 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Redline Synthetic Oil also makes this ZDDP additive. Seems to be popping up more commonly, now that the word is out ZDDP is deficient in off-the-shelf-oils and there's still a need for it in certain circumstances?.
Red Line Synthetic Oil - Motor Oil for Racing - Engine Oil Break-In Additive
Kevin L
'86 Carrera "Larry"
Old 04-01-2010, 02:24 PM
HarryD's Avatar
BTDT
ZDDPlus anyone using this in their Porsche?
Oil additive question
An Oil Additive that is worth using
What is ZDDP level of Castrol GTX 20W50?
ZDD Plus instead of EOS
ZDDP Plus Oil Additive from Eastwood
Oil Additive ZDDP +
and the ever popular: Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-01-2010, 04:27 PM
dshepp806's Avatar
idiots?
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-01-2010, 07:44 PM
89 930.
Benny771's Avatar
Someones got a poopy diaper.
Old 04-01-2010, 09:09 PM
Senior Advisor
James Brown's Avatar
You right Gary, the only true test is to have 6-7 fresh engines and put different oils in them and run them for 100,000 miles then tear them down and compare wear. everything else is just personal choice. (although I like Swepco).
08 Cayenne Turbo
Old 04-02-2010, 12:07 AM
GaryR's Avatar
Sorry, I was in a bad mood..
Gary R.
Old 04-02-2010, 06:41 AM
I know you guys have seen this.. but while you could argue a million points against its validity you cannot refute the bottom line which is the oil did not CAUSE any wear.
You hear all sorts of talk about castrol causing cam wear.. I dont think you could make any argument like that about mobil 1. I only wish they had done some high temp testing but that was not "in scope".
Mobil 1 Performance Record - Million Miles
And if you are REALLY bored.
http://www.mobil1.com.sg/academy/journey.aspx
JP
'76 911s Ice Green Metallic bone stock
Old 04-02-2010, 09:13 AM
HarryD's Avatar
Mobil 1 Oil Academy - Journey through an Engine
That is a cool test in 1990.
Since this test, two significant variables have changed: use of roller tappets and reduction of ZDDP in "energy saving" oils (current API SL/SM oils). Because of this, these results may or may not reflect the impact of their current oil formulations in older flat tappet motors.
Harry
2020 MB E350 4Matic
Old 04-02-2010, 11:06 AM
dshepp806's Avatar
ding-ding,..we've a winner!!!!!!!!!!!!!
Best,
Doyle
Middle Georgia
Old 04-02-2010, 12:37 PM
Best,
Doyle
I dont have no stinkin rollers
JP
Old 04-02-2010, 12:55 PM
AutoBahned
RWebb's Avatar
Now, I don't want to "get all epistomological on yer ass"* but in the absence of controlled, statistically valid scientific experimentation, one usually relies next on expert opinion (something akin to the clinical experience of an MD) rather than just anecdotes. Steve W. says use a good oil with adequate ZDDP and he sees a lot of motors. Charles Navarro says the same and has run various tests.
Sooooo...
* with apologies to apologies to Quentin Tarantino
Old 04-02-2010, 12:56 PM
Mobil 1 is so damn expensive these days I cant even afford an additive.. Im changing my filter 3 times between changes these days... as long as I dont get too hot I think M1 is up to the task of 6-8k.. especially with the volume of oil we run in pcars.
But hey.. this is my call.. not yours
Sooooo...
JP
Old 04-02-2010, 01:02 PM
Milo2361's Avatar
FWIW, i contacted Shell about their Rotella T 15w40 about 2 months ago, since its REALLY cheap compared to all these "racing" oils. they emailed back saying they had a minimum of 1200ppm zinc and 1100ppm phosphorus. I use this cause its economical, and if i change my oil every 3-4k miles, i think it is plenty protective. especially with 11qts..... the rotella T in a 5 gal bucket at wal-mart is about $50... that makes for around $2.50/qt...
1998.5 Ram 2500 Cummins
Old 04-02-2010, 01:11 PM
HarryD's Avatar
From what I gather, the HDEO's (Shell Rotella, Exxon Delvac, Chevron Delo) are all excellent. I recently ran Delo for 6,000 miles.
For me, the only drawback is that I prefer a 20W-50 oil. My car just seems happier with a heavier oil.
Harry
2020 MB E350 4Matic
Old 04-02-2010, 03:04 PM
AutoBahned
RWebb's Avatar
just be sure and disclose it to a future buyer of your car - they will want to figure out how long they can go before a rebuild.
This is not about the filter, the heat or the oil volume at all. It sounds like you misunderstand the issues re inadequate ZDDP.
- Glad to hear the info on Rotella
Old 04-02-2010, 04:24 PM
HarryD's Avatar
Exactly correct.
Older 911's use flat tappets not roller tappets. Per (that totally ignorant group about cars and car needs known as) SAE, that is why higher ZDDP is needed.
Harry
2020 MB E350 4Matic
Old 04-02-2010, 05:14 PM
Hi JP,
I wish we lived closer so I could show you the collection of pitted camshafts that came from engines that were run exclusively with Mobil 1.
I've seen similiar things in engines using Castrol GTX for extended intervals.
My best suggestion to you may be to educate yourself about precisely how ZDDP works (plenty of SAE papers on this) and I think you'll find that interesting and informational. For me, it was eye-opening,...........
In short, "oil ain't just oil" anymore.
That said, ultimately its your engine and one can use whatever products they choose.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-02-2010, 05:23 PM
brads911sc's Avatar
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 04-02-2010, 05:46 PM
