backdate or modify?
take a 71 tub which has already been stripped and it basically perfect condition, cut out a new pan for a later model 6 speed transaxle and 993 tt engine and full coilover all the way around
or
"backdate" a 1990 911 964 tub which already has the correct engine and tranny mounting point and suspension mounting points?
option 1:
option 2:
Old 04-05-2010, 03:44 PM
Grady Clay's Avatar
The successful option:
Backdate the ’90 and restore the ’71 to original.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-05-2010, 04:00 PM
DanielDudley's Avatar
Once a pickle, never again a cucumber.
What Grady said.
Old 04-05-2010, 04:08 PM
so all the "71" parts will work on the 90?
Old 04-05-2010, 04:17 PM
AutoBahned
RWebb's Avatar
many will
the 964 tub is much stiffer than the early one yet weighs only about 40 lbs. more
it is already fitter for coil overs and you can run wider wheels/tires with no mods needed; it is already rustproofed too - moreover, if you don't like the blobby look, you can backdate it to look like an early car
if the '71 is an E or an S tub, then it is worth money
Old 04-05-2010, 04:22 PM
is there any info out there detailing the "backdating" process or which parts swap with what?
Old 04-05-2010, 04:35 PM
Max Sluiter
Flieger's Avatar
The previous owner of my car took a 1971 911S and made a short hood. I guess now I have no reason to hold back on the modifications but there is just something about the long hood.
I think you should make a 911ST replica with a screaming 2,2 engine and a proper road-racing 911 transaxle. The 1971 is a very special, unique model year. You should celebrate that.
Or backdate the 964. Do not cut the '71. You can fund your project with it.
Old 04-05-2010, 04:51 PM
it's really an either or
i think we're gonna go with the 90 and backdate it
Old 04-05-2010, 05:08 PM
AutoBahned
RWebb's Avatar
search for a thread by a shop owner in TN - Nashville, IIRC
his name might have been PorscheDoc or something similar
or just search on 964 - this is a 911 site so there aren't a huge # of 964 posts
Old 04-05-2010, 05:17 PM
many will
it's a T
Old 04-05-2010, 05:30 PM
ERH ERH is offline
An old thread
zuffenhaus C2 to '72 RSR project...
Ed
Old 04-05-2010, 05:51 PM
