76 912E brake conversion questions
I have a 76 912e and want to install 87 944 turbo brakes. Has anyone done this, is this possible, and what do I need to complete this? Thanks
I have to ask... why? You boiling your brake fluid?
JP '76 911s Ice Green Metallic bone stock |
Just wanted to install larger two piston calipers.
Max Sluiter
All early 911 and 912 brakes are two-piston. You probably have M calipers and 20mm thick vented rotors, which are the same as for a 911. You are fine unless you have a much bigger engine in there. Try cooling first. Brakes take kinetic energy and turn it into heat. If you can get that heat out of the brakes at a fast enough rate, you can increase the amount of heat you are putting into them without boiling fluid.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
gearhead
If my memory serves, my 912e had non-vented rotors on it. Though some 911sc or Carrera 3.2 calipers and vented rotors would be a perfectly acceptable upgrade.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Max Sluiter
Look in the classifieds for a 911SC front suspension (or Carrera). People who do big race suspension upgrades sometimes sell their old parts as a unit. You can just bolt on the whole new suspension with the better brakes.
