Megasquirt-V3.57 with dual spark output
Hi
i have the opportunity to buy the above (used) to my 3.2l 1976 targa. What do u think? Will it make any noticeable change on street drive? What do i need to know before i start?
911 TARGA 1976 - 3.2L, G50 SHORT BELL HOUSING. Toyota Hilux 4x4 2000 VW tuareg 2009 3.6 HONDA SH350 |
Baruch,
I like Megasquirt, but I recommend that you read up on the specifications, tuning procedures, etc.....and tap into the forums to read about others experiences. start here: * *MegaSquirt - Electronic Fuel Injection Computer by Bowling & Grippo * * regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Unless you are planning some serious modifications to your engine, I don't think megasquirt will add much over your Motronic controller but will cause you to spend an enormous amount of time and energy retuning your system. MS will allow you to get rid of your "barn door" MAF which may improve throttle response and top end HP slightly but I don't think it would be worth the aggravation.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
It depends... there are alot of factors... I use MS V 3.57. It is a breeze to tune with Tuner Studio if you have a good AFR table... the install of EFI and Recurving the Distributor made a world of difference in throttle response. I was coming from CIS however so cant speak to Motronic. Id think that a performance chip would be alot cheaper and less work. May want to seek out Jaime Novak. He is an MS guru and gave me the ARF table that proved to be spot on. He also quickly picked out errors in my install that prevented hours of difficult troubleshooting.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
The Motronic EFI on the 3.2 is already a pretty good system which also controls ignition timing and uses low-Z injectors. Changing to MS will require a lot of rewiring, changing to high-Z injectors (or building low-Z fly-back circuits for P&H control or addition of injector resistors), optimally addition of a wideband O2 controller, etc. If going to ITB's, distributorless twin-plug ignition, and/or turbo, it makes some sense.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold Last edited by sjf911; 04-14-2010 at 08:42 AM.. |
I agree. I went with ITB's on mine. Not sure if you keep all the motronic fuel hardware, that you are going to gain much by just swapping out the ECU. what problem are you trying to solve? This will be alot more involved than just plugging in a new ECU. Injectors, wiring harness, Wideband, misc will easily add $500 to your ECU costs... also I think that with CIS to EFI or ITB/EFI, there are alot of base maps out there from people who did it. Adding an MS ECU to Motronic Hardware is probably uncharted waters... wont be nearly as easy to tune due to the lack of a DIY knowledge base...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 04-14-2010 at 10:48 AM.. |
Baruch,
I use a dual plug MegaSquirt system on my turbo engine. I'm very happy with the outcome, both in the drivability as well as the power results. However, I would echo some of the observations above, you would probably be better off with a chip upgrade unless you plan major modifications to the engine. If you end up going with MS, drop me a line and I'll share my most recent configuration.
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
tnx all, exhausts and chip is allready in...
Thread Tools | |
Rate This Thread | |
