ryansiok's Avatar
Unstable Idle Issue
I have an '87 911 Carrera that normally runs perfect, but just recently it started having this unstable idle. It usually happens if I'm cruising with the rpm's above 3k or so and then I let off the throttle to come to a stop. The idle starts to drop like normal, but then sticks between 1200 and 1400 rpm's. After about 10 seconds of this high idle (not touching the throttle at any point) it will drop down to it's usual ~900 rpm's.
If I punch the throttle while it is idling high, it will rev up as expected and then fall to its normal engine speed (~900 rpm's).
Any ideas?
1997 BMW M3 Coupe
1989 VW Jetta GLI
1967 Vespa Gran Tourismo
Old 04-23-2010, 07:09 PM
Binding throttle cable.
Old 04-23-2010, 08:23 PM
Northern Motorhead
wildcat077's Avatar
Have a look at the linkage where it connects to the transmission... I had to take mine apart and clean & lube the bushing because my throttle would hang as well !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-23-2010, 08:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
When it is safe, pull over and pop the lid, take a butt of a screw driver and tap firmly on the ICV, if it settles down, you may need to pull the ICV and clean it. Search Threads.
To do a proper check, check the OHMs per Bentley.
'85 Carrera Targa
PCA/POC
Old 04-24-2010, 10:51 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
sounds like a sticking throttle cable to me. I had a similar problem. start at the throttle body and work your way forward.
Hanging Idle fixed
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 04-24-2010, 12:55 PM
muck-raker
kidrock's Avatar
I'm with Wildcat077 on this one...the linkage on these cars usually seem to stick in the area where it attaches to the trans, as soon as the weather warms. Disassemble, clean, lube, reassemble.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-24-2010, 05:59 PM
ryansiok's Avatar
Thanks for all the replies! I'll start with checking the linkage and lubricating along the way. I was thinking it could be the ICV/ISV as Draco said, so maybe I'll give that a clean too.
1997 BMW M3 Coupe
1989 VW Jetta GLI
Old 04-25-2010, 09:24 AM
ryansiok's Avatar
Simple. Just needed to lube the throttle linkage at the transmission. Thanks for all the help.
1997 BMW M3 Coupe
1989 VW Jetta GLI
Old 04-25-2010, 03:24 PM
