I would tap and plug them... they should work nicely with your carbs
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-04-2010, 02:32 PM
Jbell, I appreciate the encouragement. I will get them tapped and plugged.
Once again, Pelican to the rescue. I can't imagine how I would have figured this out without everyone's help. Thank you.
John
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver
1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green
1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet
Old 05-04-2010, 04:10 PM
Walt Fricke's Avatar
There are many ways to plug these holes. I ended up with an engine with early MFI heads. The injector holes had been tapped, and allen bolts screwed in. Problem was that the bolt heads stuck up a bit too far for the PMO manifolds I purchased. Some quick work with a die grinder solved that.
But were I to use heads which needed a plug again, I'd try to use allen head set screws to get them out of the way. Or perhaps see if 1/8" aluminum or brass NPT plugs would work. Or find a lower profile bolt. Anything to keep all of the plug below the plane of the intake gasket.
Old 05-04-2010, 05:54 PM
