Originally Posted by stlrj View Post
So guess what...you're probably wasting your time and will still have that pull to the right when you're done.
At this point, you are better off abandoning your caliper rebuild for a couple of beers and I'll see you at the Civic Center on Sunday.
Cheers,
Joe
Ahh, the Bay to Breakers Race. But that is on Saturday.
What is going on Sunday at the Civic Center? There is a huge metal sculpture there. Very cool.
'71 911T Sporto
'68 300SEL 6.3
Old 05-13-2010, 04:34 PM
The printout could not have made it more clear. Left front camber -1.1 degrees compared to +0.1 degrees on the right?
"The tech came over to the counter and showed me the results of the alignment stating that he could not make all the numbers come in as it was at the adjustment limits." ....Hmmmm
Looks like a red flag to me! A bent strut/spindle would certainly be on the top of my list.
Cheers,
Joe
Wow, a bent strut... i.e. the shock absorber? Could this offset in the alignment numbers be visually noticeable?
'71 911T Sporto
'68 300SEL 6.3
Old 05-13-2010, 04:40 PM
The Civic Center is more or less the same as the Marin County Fair Grounds...you know, the Concours.
Old 05-13-2010, 04:50 PM
Depends how far you stand back and look.
Old 05-13-2010, 04:53 PM
Rrright! You are closeby.
'71 911T Sporto
'68 300SEL 6.3
Old 05-13-2010, 05:49 PM
Zeke's Avatar
Corner balance.
Old 05-13-2010, 06:33 PM
UPDATE:
Starting a new Topic under "911T Sporto Brake Calipers Frozen...Help!"
Once I get the brakes back in shape I will continue the wheel alignment saga... stay tuned!
'71 911T Sporto
'68 300SEL 6.3
Old 05-13-2010, 10:15 PM
Under the radar
Trackrash's Avatar
You should also check the attatchment from the strut to the ball joint. These can come loose on these cars.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-14-2010, 08:28 AM
OK. If your strut/spindle is not bent, there is a possibility that your left front wheel bearing is loose too.
Old 05-14-2010, 11:34 AM
Visually the strut looks straight and attached to the wishbone. Wishbone looks okay as well.
How do you check for wheel bearing looseness...with wheel on, see if there is play at 12 & 6 and 3 & 9 o'clock positions?
'71 911T Sporto
'68 300SEL 6.3
Old 05-14-2010, 12:26 PM
"with wheel on, see if there is play at 12 & 6" and off the ground.
Old 05-14-2010, 01:06 PM
Here are some pics of the wishbone area. There are two tabs with a hole thru them and are bent slightly...what are they for??
'71 911T Sporto
'68 300SEL 6.3
Old 05-14-2010, 01:27 PM
tobluforu's Avatar
And where was the marin county fair held before, no cheating now?
Old 05-14-2010, 01:32 PM
tobluforu's Avatar
Sway bar attachments.
Old 05-14-2010, 01:33 PM
Front sway bar a standard equipment item?
'71 911T Sporto
'68 300SEL 6.3
Old 05-17-2010, 10:10 AM
Got to the event on the late side(1pm). The Porsche Corral was thinned out. The Porsches in the competition were nice. Somehow I was underwhelmed by the variety of Porsches present.
Will post pics in the appropriate forum area.
'71 911T Sporto
'68 300SEL 6.3
Old 05-17-2010, 10:16 AM
tobluforu's Avatar
On certain cars, yes. Look under to see if it's attached via a nut as some after market bars supply the u-tab which allows you to drill a hole and attach it with a nut.
Old 05-17-2010, 10:18 AM
Okay. Got the brakes in order and returned to the alignment shop.
I watched over and worked with this different technician at the same shop.
The numbers improved in the rears: -1.4 camber.
The fronts were hitting the limits to the point that he could not even balance the camber:
-2.0 left 0.4 on the right.
The recommendation was to grind the holes out to get more range! Is this uncommon?
I have no ideal how old the front struts are, perhaps this could be the problem as well.
Also the car is likely lowered (not my me) as this was often done for appearance sake.
Any recommendations?
Will post pics later...
'71 911T Sporto
'68 300SEL 6.3
Old 05-26-2010, 12:46 PM
HarryD's Avatar
Go to a shop that sets up Porsches for the track. They will know what to do and how to get you there.
I had my car lowered, aligned and corner balanced by Rothsport Road abnd Race and the results were amazing. Costwise, it was about the same any any other decent shop.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-26-2010, 03:08 PM
Regis turd ab user
Here's some info regarding cars that are refreshed without questionable issues, age of shocks, strut inserts, etc.
Need Alignment Help
Old 05-26-2010, 04:01 PM
