Author of "101 Projects"
New 959 Project - Replacing the Suspension Accumulators...
After months (years?) of working on the 3.4 Boxster conversion, it's finally time to get back to working on the 959. The suspension accumulators are shot on this car, so I will be replacing them. I have had this problem with the car for almost two years now, but just have been really, really busy with the Boxster conversion (see here on the Boxster: Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
For more information on the problem, see this thread from 2007: Next Project on the 959: Fixing the suspension bounce... First step, prep the garage and the lift. The 959 has a Nomex underbody, so there's really not too many places to pick it up and place a jack stand. Using a lift is *almost* mandatory for working on the car. ![]() Now, move the car into position over the lift. You have to make sure that you don't scrape anything on the lift while driving it over. The 959 has a suspension that will raise and lower itself (like the new Panamera), so I just put it on "high" and drove it over the lift. This is convenient. ![]() Start the lift and then check to make sure that the pads are aligned precisely with the lifting points on the car. With so much carbon kevlar and very expensive replacement parts, you want to make sure that you get this part right. ![]() With the car still on the ground, you want to loosen up the wheel that we will be working on. The 959 has these crazy-huge center caps. To the untrained eye, they look just like normal 911 caps, but when you look closer, you will see they are about 2X the size. I couldn't find my plastic pry bars, so I simply wrapped a screwdriver with some duct tape to protect the finish of the cap and the wheels. The caps are no longer available from Porsche (I bought the last two they had about two years ago, for use as spares). ![]() Underneath is the center lock nut: ![]() Check this out, the 959 has this really funky wheel locking system. Incredibly complex. You insert your ignition key into the center lock to remove the center holder: ![]() Now, pull out that center holder:
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
So, the torque on that center nut is so high that you need a special planetary tool to remove it. This tool is a reducer that fits specially into the 959 wheels. You never want to lose this tool - without it, you can never get the wheels off. New ones aren't available, and I would think that if you had one and someone didn't it would be worth several thousands of dollars.
Here's the center nut: ![]() Here's the tool: ![]() ![]() ![]() Here's how it fits into the wheel: ![]() A big breaker bar with lots of force is required here: ![]() Now that I've loosened the wheel, it's time to raise the car. One more check to make sure the pads are properly aligned: ![]() And up she goes:
Now, with the car up in the air, you can spin the center lock nut off:
![]() and then remove the wheel: ![]() Here's a close-up photo of one of the shocks that will be replaced. The 959 has two separate shocks on each corner: ![]() Tomorrow I will post photos of the accumulator and the process of depressurizing the hydraulic lift system. I will also be installing a pressure gauge on the line in order to test the units prior to me removing them. The method for depressurizing the system involves disconnecting the auto-level sensors and then dropping the car back down again - I hope I can reach in there and do that without having to remove all the wheels (and then put them back on). Stay tuned! -Wayne
Almost Banned Once
I've said this before but that car is so well engineered it makes you wonder if a car like this will ever be built again.
Thanks Wayne. I always look forward to these updates.
- Peter |
Platinum Member
Is this the start of 101 projects for your 959?
![]() 1- remove wheels 2- Jack up car 99 projects to go........ kidding..... keep us posted..... that gearbox for the wheels is crazy! |
Model Citizen
subscribing
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Even with the low # of 959's produced it may be worth the while to machine out a few of those planetary tools. Make a couple a grand!
MBruns for President
clean those wheel wells!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I love these 959 threads...
I can't wait until Wayne decides to upgrade the.....never mind any upgrades, I just like seeing the engineering....
tk 08 911 C2S - Sold 13 Audi A4 14 Jeep SRT 500HP |
Almost Banned Once
This one is $2,731.50 USD (3200 ft. lb. Output)... It obviously wouldn't fit the 959 wheel and centre bolt but maybe you could modify it. YA393, Torque Multiplier, Geared Head, Bar Reaction, 3200 ft. lb. Output
- Peter |
Amazing engineering!
David 1972 911T/S MFI Survivor |
That is a pretty amazing car. Wayne, you are probably one of just a handful of guys that DYI on a 959.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Wash. State
....now I'll never get my free coffee mug....
I don't think anybody thinks the 959 is the best looking car on the planet, but the technology, especially considering the age, is incredible.
Wash. State
Granted.....but I'm sure I've said enough....
It looks great in its rally setup!
Happiest when Tinkering
Thanks for the pics Wayne that car would be a lot of fun to work on too rich for my blood though good luck with your project.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
959
All we got was a ride at Weissach...............
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Wayne,
Why are there crossover tubes on both top and bottom of that caliper?
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
Wayne,
Thanks for sharing your project on your 959 with us. About the planetary tool it's both ingenious and complicated! I was wondering how you keep the wheel from turning when you loosen the wheel nut but noticed that the planetary tool takes care of this problem.
MikeD '87 930 |
