grahamkissack's Avatar
The part of my SC I hate the most right now
Getting ready to remove A arms for new bushings....guess what won't come off despite my pounding the crap out of it despite weeks on PB application (ps JWalker was right!)?
Many have talked about using a pipe wrench / extension on the nut on the ball joint but I only see about 1/8" of width to grab the nut....any pics on how to do that? where do you grab with pipe wrench?
"Penelope" 1980 SC Targa in Grand Prix White
Old 05-24-2010, 08:40 PM
As I posted to your previous thread: A Arm removal - easier to remove top or bottom of ball joint?
You have run into precisely the problem I had with my '80SC. To remove the ball joints, you'll need an at least 18' pipe wrench with some pretty sharp teeth. I know there is only about an 1/8in to work with on the nut, but pull the cotter pin out, remove the "disc", and get as good a grip as you can with the wrench. Believe me, it can be done. To get the wedge pins out of your struts, I would suggest you remove the struts after you get the balljoints loose. Put them in a vise or something solid and use a large punch or drift and beat the pins like hell. Hopefully they will turn loose! Next problem, your balljoint shaft will be stuck in the strut. You'll need a suspension "pickle fork" to separate them.
My job that I thought would take a couple of hours became an all day affair, due to those damned wedge pins! Good luck!
Grant
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-24-2010, 09:36 PM
Grant
Thanks uwanna...so when the pipe wrench is in contact and starting to turn the nut...should it be facing directly out from the wheel well? ie at 90 degrees to the car or should it be paralle to the car...just confused on the best angle to grab it at??
Old 05-24-2010, 09:41 PM
grateful user
don gilbert's Avatar
Take a dull chisel and hammer and wack them loose once the safty retainer is off. You are going to mess them up with a pipe wrench any way, but they can be reused a few times either way you do it. There is a special spanner wrench to take off the ball joint nut. I think the nuts are around 20 bucks apiece.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-24-2010, 09:44 PM
SP2 SP2 is offline
SP2's Avatar
If it's the wedge pin you can't get out, back the nut off a few mm, then hit it to force the wedge pin out the other side.
Old 05-24-2010, 10:24 PM
Do what SP2 said to do. It worked for me too!!!!!!!!!!!!!
Old 05-25-2010, 04:01 AM
brads911sc's Avatar
I used an air hammer on the nut. also use heat to melt the loctite... came right off...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-25-2010, 04:34 AM
KNS KNS is offline
On the driver's side neither would budge on mine either. I tried the pipe wrench, the hammer and chisel - nothing! I finally cut it off with a Dremmel - five minutes. Why did I waste so much time on the other methods. On my wedge pin, It would not come out. Finally bought a very nice dead-blow hammer (with punch) and pounded on it.
Strangely, the pass side came apart easily.
Kurt
Old 05-25-2010, 05:10 AM
Tim
Send a message via MSN to tvanbroekhoven
Castle nut -> Dremel
Wedge Pin -> BFH
When I was doing this job I also lubricated myself with some beer on a regular basis to minimize the wear on my nerves
Old 05-25-2010, 07:49 AM
