DIY wrencher
Originally Posted by azhodge View Post
I got one of these 66.5 x 80.0 sockets. seems way loose on the nut. catellated nut seems like a 52.0. But if it work for you then I will give it a try. I would feel better if that big sloppy gap was not around the edge and it was snug. Four teeth also not fully engaged.see pic
I was about to order the cheap tool from Amazon but in that case if it just "kinda" works I would rather find a tool with the right size.
Has anybody found out in the meantime if there is another aftermarket socket that fits perfectly?
Old 04-24-2019, 12:39 PM
Been here a while
I bought one from Pelican user JimmyT, he shipped it immediately and it worked flawlessly, super easy, really well made....and happy to support a contributor to the community
see this thread
Removing Ball Joints w/ Control Arm/Struts on Car
looking for 1972 911t motor XR584, S/N 6121622
Old 04-24-2019, 12:45 PM
Harpo's Avatar
Originally Posted by wswilburn View Post
The tool is not made of hardened steel. One slip and the points can be rounded. I use a floor jack to press it against the nut and have had success every time.
I agree, you must keep lots of pressure on the socket to prevent it from camming off
Old 04-24-2019, 02:37 PM
piscator's Avatar
Is JimmyT a member here? How can I contact him to buy his socket!
Robert
"A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe)
Old 04-24-2019, 03:45 PM
DIY wrencher
Thanks for the tip David!
I am already in touch with Jimmy, he is definitely the man for this tool!
I'll PM you his email address so he doesn't get spammed if I post it publicly.
Old 04-24-2019, 03:53 PM
piscator's Avatar
Lukas, thank-you! I'm about to start re-assembling the front suspension and that socket would be a BIG help!
Robert
Old 04-25-2019, 04:21 AM
