All--
I have a strange rubbing noise and slight vibration in the steering wheel between 60-70 miles per hour. Most times it goes away when I ease off the gas and resumes when I go back on the throttle. I checked to be sure its independent of engine RPM. Its otherwise handling and driving great--no noise / vibration below or above that speed range. I don't see anything rubbing, checked the lug nuts, and confirmed good tire pressure. I haven't had an alignment in a while (>20,000 miles or ~3 years) and the tires only have ~17,000 miles on them. I'm due for an oil change and plan to have it looked at while its with the shop, but want to get a sense of what I might be dealing with. thanks, David
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
Balancing OK on the tires?
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
muck-raker
wheel bearings lubed and adjusted properly?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I had the front bearings replaced less than 5000 miles ago. Could that be it?
muck-raker
I dunno, just a guess. While it's parked, grab a tire at the 3 o'clock and 9 o'clock positions and work the wheel back and forth to test for play. Any play in the wheel might be a sign.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
+1 on the balancing.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
