Cattler's Avatar
Porsche Crest Strange rubbing noise / vibration at speed
All--
I have a strange rubbing noise and slight vibration in the steering wheel between 60-70 miles per hour. Most times it goes away when I ease off the gas and resumes when I go back on the throttle. I checked to be sure its independent of engine RPM.
Its otherwise handling and driving great--no noise / vibration below or above that speed range.
I don't see anything rubbing, checked the lug nuts, and confirmed good tire pressure. I haven't had an alignment in a while (>20,000 miles or ~3 years) and the tires only have ~17,000 miles on them.
I'm due for an oil change and plan to have it looked at while its with the shop, but want to get a sense of what I might be dealing with.
thanks,
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 07-13-2010, 04:30 PM
dshepp806's Avatar
Balancing OK on the tires?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-14-2010, 01:20 PM
muck-raker
kidrock's Avatar
wheel bearings lubed and adjusted properly?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-14-2010, 01:32 PM
Cattler's Avatar
I had the front bearings replaced less than 5000 miles ago. Could that be it?
Old 07-14-2010, 04:17 PM
muck-raker
kidrock's Avatar
I dunno, just a guess. While it's parked, grab a tire at the 3 o'clock and 9 o'clock positions and work the wheel back and forth to test for play. Any play in the wheel might be a sign.
STONE
Old 07-14-2010, 04:21 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
+1 on the balancing.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-14-2010, 07:41 PM
