gearhead
What would I do if I had $10,000 to throw at my car?
I would build the most ridiculous 915 gearbox you've ever seen...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
And what would that look like Matt ??
L8brkr,
I already have my fun road racing Spec 125cc go karts ![]() I have no intrest in selling my car. If I wanted a 996 or 993 I'd of bought one instead of the SC, not that they're not nice, I just like the older ones. I thought about a backdate but before I do anything like that I want to get the car mechanically sound, then I'll do the "pretty stuff" down the road, maybe. I do like the professional instruction idea though, driving this car is considerably different than a go kart, for now
Drop engine and replace all leaking seals, worn hoses, clutch if it needs it.
Replace suspension bushings and shocks if necessary. Have seats recovered by Tony at Autobahn and carpets replaced if necessary. That's it. What you don't spend on that, you save. Trying to accomplish much with $10k on an SC is pretty much impossible. Any modifications you would make would take the car a small percentage of the way to where it ought to be. E.g., engine mod requires suspension and brakes. Suspension mods require you to commit to the whole DE thing, e.g. seats, rollcage, harnesses, fire system, tires, bumpers. What you want to accomplish is improvements that will bring the car back closer to stock in terms of your enjoyment and resale value. Moving away from things, while possible, requires a lot bigger investment than $10k to reach a plateau where value is restored. My $0.02, your car! Good luck!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
gearhead
LSD $2495
Billet Mainshaft $1575 Gears 5x$725= $3625 8:35 ring and pinion $2795 Sidecover: $425 Billet 3/4 fork: $300 Bearing Plate: $295 Custom oiling: $1500 Shifter: $700 Sliders, synchros, bearings: $3000 Total: $16,710.00 Looks like $10k isn't enough...
Ouch !!! - thanks Matt
John |
Now in 993 land ...
Sell SC and buy 993. That's what I did ... it took a little more than 10k though ... but I wanted better brakes, bigger wheels etc. and would have sunk 5k+ in the SC.
George |
If I was not building it into a race car an it was a car I used as a driver, I would sell it an put the extra 10K towards a newer car car for the street.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Hey Mickey:
I am with you on this one! Keep the SC, they are very cool cars. What I did entailed buying new Bilstein's for all four (4) corners and I replaced the bushings. Then, I purchased four (4) new tires from Tire Rack for the 16" Fuchs which are 7's up front and 8's in back. Next, I will replace the camberplates. Not sure which type I should go with yet though. And, I will probably install a Cambermeister strut bar. I'll keep you posted. Just my .02. Good luck and enjoy your 911SC.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
RETIRED
Add 5k more, put in a 3,6, reinforce the 915 and beef up the suspension.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
gearhead
There's definitely cheaper ways to build a 915 and make some compromises. But if cost were no object and one wanted something that really does the trick, that's the "formula" if you will. You could leave out the ring and pinion and stick to gear changes only. The cooler also isn't required if you don't race, and putting a factory cooler on it instead would be an option. Getting it under $10k is totally doable with a little tweaking...
If its gonna "go", its gotta "whoa",...
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Karts rock. I spent eight years in FF1600 and FF2000. Loved the winged cars. Still want another one. Since you have the cart, I'd do the suspension, a mild brake upgrade, and get a second set of wheels and R-comp tires. Spend the rest on track time. The best way to progressively improve driving the SC.
But that's just me. YMMV, JMHO, etc. |
nice doggie
Spend what's needed to make it look good and drive reliably. Probably won't take $10K if your car is in pretty good shape to begin with.
Jerry 78 SC hotrod 02 Mini Cooper S |
Senior Member
I've already done substantial small stuff (torsion and sway bars, bushings, shocks, engine fresh, tranny fresh, blah blah), so I'd prolly drop in a 3.6.
Then again, perhaps a roll cage, carbon fiber race buckets, glass hood, fenders and deck lid.....
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I saw a late 964 C2 black on black (no, it wasn't tiptronic) with ~48k on it for around 20 grand the other day.
Sell your SC, take your 10k, buy it and tune to suit your personal tastes... Or keep your SC add do DIY suspension, wheels/tires, brakes refresh....add a rennshift n wevo coupler and some other fun bits.
Sepia brown 1971 911T. |
There is a good reason why supply swamps demand for 996s. I drove a 996 once, and I can't understand why anyone would prefer one over an air-cooled 911.
Charles '84 911 3.2 |
