If you had $10K to spend on your SC you would?
I may be coming upon some money in the next few weeks to spend on my SC and was wondering what you all would do if you were me (maybe?)?
Just had a top end done, already have turbo tie rods, pop off, chain tensioners, SSI's & M&K, Rennshift with Wevo coupler. I only plan to drive the car on the street mainly with a DE or track day every once in a while.
My intial thoughts were - refresh stock suspension, new brakes F&R (I'd like to do drilled rotors but I heard they're not all that), new seats, RS door panels, RS carpet, Rota RSR finish (or a set of RSR finished 16's), New seats (Cobra RS's or Nurbs).
Anything else?
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 08-14-2010, 09:13 PM
Mitch Leland's Avatar
Why don't you post some pixs of your car, then I bet we could help you spend your money in a hurry. Since you just had a top completed on your engine then we can assume your clutch and transaxle are in good shape?
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 08-14-2010, 09:45 PM
jwetering's Avatar
Suspension would be the first thing - some stiffer torsion bars first, then some good shock absorbers. Not too stiff on the t-bars IMO. 22/28 worked for me, with Bilstien heavy duty shocks...I left my sway bars stock. I had zero complaints with this setup on both street and track. Of course Neatrix bushings in the back and geez the elephant poly bronze in front were sweet.
If you're writing a cheque to get all this done then you may not have a lot of change left out of your $10K. If you do some or all of this yourself then you'll have money left over for....brakes.
I hear the Boxster brakes work ok...I also understand that 930 brakes are *really* good. This will take car of the rest of your cash.... Drilled rotors alone won't do anything for you...look good maybe.
A good seat is worth the effort. I'd stick to Fuchs for wheels if you're upgrading those. Very few aftermarket wheels look right on a vintage 911 (again just my opinion).
Post some pics dude.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 08-14-2010, 09:50 PM
vash's Avatar
$10k? crazy..
i cant believe i'm even going to say this...but i would NOT do it..save it?
i'll leave now....
poof! gone
Old 08-14-2010, 10:02 PM
If I read your post correctly you want your car set up for the street and a couple of DE's a year, and or a "track day once in a while". If that's the case you're spending a lot of money on suspension and giving up some ride comfort for 2 or 3 track days. I would put in some time at the track, then see how far you want to go with the suspension. Yes on the brakes, you can't go wrong there...
Mitch Leland
Old 08-14-2010, 10:09 PM
crustychief's Avatar
Buy it's twin?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-14-2010, 10:10 PM
m110's Avatar
Seats
Tires, potentially wheels
Suspension bushings and shocks
New windshield
Steering wheel
1988 Carrera Coupe
Old 08-14-2010, 10:13 PM
If you are so happy with the car that you have to ask.
Spend the 10k on gas and tracktime, enjoy what you have.
Regarding brakes most important update is airducts, after having that installed there is rarely need for more updates on brakes.
911 1966 untuched exept 2,2E MFI -70 engine
Old 08-14-2010, 10:25 PM
disband
juanbenae's Avatar
sell it & you'll have 18K! i made mine into a race car cause it was cheaper than buying a beater....
Old 08-14-2010, 11:10 PM
Put a 3.6 in it.
Running a 95 993 motor in an SC....
Old 08-15-2010, 02:09 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Arrow Oh baby...
Originally Posted by burgundyben View Post
Put a 3.6 in it.
Yesssssssssssss...
Mine was born with a 3, she is now fitted with a 3.2 and if she ever need another engine, she'll get a 3.6
Who Will Live... Will See
Old 08-15-2010, 04:23 AM
sancho
sancho's Avatar
since you already did some work on it......
supercharger??????
1980 SC targa blue-SOLD
1986 Carrera wide body white
Old 08-15-2010, 05:29 AM
GaryR's Avatar
Send a message via ICQ to GaryR
I would put in new 28/22 hollow torsions with a full ER polybronze/monoball setup. Stock brakes are more than adequate, drilled rotors are crap, stick with stock Porsche rotors and pads for a 95% street car (and I would only do better pads for the track, still use stock calipers/rotors). If changing seats possibly add a bolt in roll bar to allow use of a 5-6 point harness when on the track. Only issue is you need to do both seats equally if a student to run in PCA DE's..
Gary R.
Old 08-15-2010, 08:04 AM
grudk's Avatar
Echoing what some have said, sell your car, add 10K and buy something much nicer. For low 20s, there are a lot of very well-prep'd cars out there. Should be able to buy a car whose owner has about 60K into it (30 cents on the dollar return). Of course, I didn't take that advice, either, so...
Now Porsche-less
ex-'74 Carrera, '93 RS America, '89 Cab, '88 Coupe
“Thank god there’s no 48-hour race anywhere in the world, because chances are nobody could beat Porsche in a 48 hour race.” Carroll Shelby, 1972.
Old 08-15-2010, 08:17 AM
5String
Fortunately, my car is in pretty good shape so I don't think I could make a case for spending that much money on it. (Ask me in a year to see if this still holds true.) I might want to put shocks and suspension bushings on it, and upgrade the A/C, but I doubt this would burn through a $10,000 bill.
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 08-15-2010, 08:31 AM
With a fresh top end, you've got a good, known quantity. I say ditch the CIS for a modern fuel injection setup. ITBs, Carrera 3.2 intake with aftermarket ECU, or 3.6 intake over ITBs. Many possibilities.
Old 08-15-2010, 08:41 AM
Paper Member
You SHOULD give it to someone like me so my SC doesn't drag down the SC image.......
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 08-15-2010, 08:48 AM
scottrx7tt's Avatar
if it were me, i would upgrade to a modern EFI system, and custom make a turbo kit for it, maybe even use the exhaust portion from a 930...... Or maybe you would be better off selling your motor, and buy a used 930 setup.
Old 08-15-2010, 08:57 AM
Smartbag Porsche 911 SC
Send a message via MSN to smartbag
I would rebuilt the engine and tranmission at motormeister in LA. You would only spend about 6K and have the remaining 4k for other things.
Old 08-15-2010, 09:07 AM
I'm here to cause trouble
jimbauman's Avatar
You can't JUST put a 3.6 in it. If you do, your last conscious thought will be (just before you hit something) ".... oh crap... I should have upgraded the brakes too!!"
Having said that, I'd upgrade the brakes, followed by a suspension refresh as mentioned above, followed by seats, maybe a harness bar and 5 point harnesses.
Then after ALL that, the car will be ready for a power upgrade if you ever decide to go that route.
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 08-15-2010, 09:23 AM
