gearhead
What would I do if I had $10,000 to throw at my car?
I would build the most ridiculous 915 gearbox you've ever seen...
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-17-2010, 02:48 PM
And what would that look like Matt ??
Old 08-17-2010, 03:42 PM
L8brkr,
I already have my fun road racing Spec 125cc go karts
I have no intrest in selling my car. If I wanted a 996 or 993 I'd of bought one instead of the SC, not that they're not nice, I just like the older ones.
I thought about a backdate but before I do anything like that I want to get the car mechanically sound, then I'll do the "pretty stuff" down the road, maybe.
I do like the professional instruction idea though, driving this car is considerably different than a go kart, for now
Old 08-17-2010, 05:59 PM
304065's Avatar
Drop engine and replace all leaking seals, worn hoses, clutch if it needs it.
Replace suspension bushings and shocks if necessary.
Have seats recovered by Tony at Autobahn and carpets replaced if necessary.
That's it. What you don't spend on that, you save.
Trying to accomplish much with $10k on an SC is pretty much impossible. Any modifications you would make would take the car a small percentage of the way to where it ought to be. E.g., engine mod requires suspension and brakes. Suspension mods require you to commit to the whole DE thing, e.g. seats, rollcage, harnesses, fire system, tires, bumpers.
What you want to accomplish is improvements that will bring the car back closer to stock in terms of your enjoyment and resale value. Moving away from things, while possible, requires a lot bigger investment than $10k to reach a plateau where value is restored.
My $0.02, your car! Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-17-2010, 06:23 PM
gearhead
LSD $2495
Billet Mainshaft $1575
Gears 5x$725= $3625
8:35 ring and pinion $2795
Sidecover: $425
Billet 3/4 fork: $300
Bearing Plate: $295
Custom oiling: $1500
Shifter: $700
Sliders, synchros, bearings: $3000
Total: $16,710.00
Looks like $10k isn't enough...
1974 914 Bumble Bee
2009 Outback XT
Old 08-17-2010, 06:27 PM
Ouch !!! - thanks Matt
John
Old 08-17-2010, 07:02 PM
Now in 993 land ...
aigel's Avatar
Sell SC and buy 993. That's what I did ... it took a little more than 10k though ... but I wanted better brakes, bigger wheels etc. and would have sunk 5k+ in the SC.
George
81 SC (sold)
Old 08-17-2010, 08:05 PM
Jeff Alton's Avatar
If I was not building it into a race car an it was a car I used as a driver, I would sell it an put the extra 10K towards a newer car car for the street.
Cheers
www.turn3autosport.com
Old 08-17-2010, 08:47 PM
TibetanT's Avatar
Hey Mickey:
I am with you on this one! Keep the SC, they are very cool cars.
What I did entailed buying new Bilstein's for all four (4) corners and I replaced the bushings. Then, I purchased four (4) new tires from Tire Rack for the 16" Fuchs which are 7's up front and 8's in back.
Next, I will replace the camberplates. Not sure which type I should go with yet though. And, I will probably install a Cambermeister strut bar. I'll keep you posted.
Just my .02.
Good luck and enjoy your 911SC.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 08-17-2010, 09:15 PM
RETIRED
Joe Bob's Avatar
Add 5k more, put in a 3,6, reinforce the 915 and beef up the suspension.....
2012 ML350 3.0 Turbo Diesel
Old 08-17-2010, 10:12 PM
gearhead
John
There's definitely cheaper ways to build a 915 and make some compromises. But if cost were no object and one wanted something that really does the trick, that's the "formula" if you will. You could leave out the ring and pinion and stick to gear changes only. The cooler also isn't required if you don't race, and putting a factory cooler on it instead would be an option. Getting it under $10k is totally doable with a little tweaking...
1974 914 Bumble Bee
2009 Outback XT
Old 08-18-2010, 08:44 AM
Excellent plan, but don't forget the brakes.
If its gonna "go", its gotta "whoa",...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-18-2010, 08:47 AM
Originally Posted by mickey356 View Post
L8brkr,
Karts rock. I spent eight years in FF1600 and FF2000. Loved the winged cars. Still want another one. Since you have the cart, I'd do the suspension, a mild brake upgrade, and get a second set of wheels and R-comp tires. Spend the rest on track time. The best way to progressively improve driving the SC.
Old 08-18-2010, 09:58 AM
DL Lawrence's Avatar
George
Thinking along the same lines, I would sell the SC, and buy a nicely sorted G50 Carrera for 20K. There are some great buys out there right now... you'd be amazed, I think, at how nice a Carrera you could buy for 20K.
But that's just me. YMMV, JMHO, etc.
Old 08-18-2010, 10:25 AM
nice doggie
Hetmann's Avatar
Spend what's needed to make it look good and drive reliably. Probably won't take $10K if your car is in pretty good shape to begin with.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 08-18-2010, 11:26 AM
Senior Member
Superman's Avatar
I've already done substantial small stuff (torsion and sway bars, bushings, shocks, engine fresh, tranny fresh, blah blah), so I'd prolly drop in a 3.6.
Then again, perhaps a roll cage, carbon fiber race buckets, glass hood, fenders and deck lid.....
Mocha 1978 911SC. "Coco"
Old 08-18-2010, 02:38 PM
deathpunk dan's Avatar
I saw a late 964 C2 black on black (no, it wasn't tiptronic) with ~48k on it for around 20 grand the other day.
Sell your SC, take your 10k, buy it and tune to suit your personal tastes...
Or keep your SC add do DIY suspension, wheels/tires, brakes refresh....add a rennshift n wevo coupler and some other fun bits.
Sepia brown 1971 911T.
Old 08-18-2010, 06:12 PM
Originally Posted by stlrj View Post
Take a look at Craigslist. It seems to be a supply/demand issue if you compare the prices of a 98 993 compared to a 99 996.
There is a good reason why supply swamps demand for 996s. I drove a 996 once, and I can't understand why anyone would prefer one over an air-cooled 911.
Charles
'84 911 3.2
Old 08-20-2010, 12:12 PM
