brooklyn ny 11234
hello need quick fix
the engine lid missing one nut for hold down there are 3 instead of 4 no damage to hole is still the same size quick fix for replacing the nut
thx in advance mike |
I'd like to help but I have no idea as to what you are talking about.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Nor do I. Why not get another nut?
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Captured or welded in nuts?
Bob Hutson |
brooklyn ny 11234
this is the nut that goes inside lid i think they might slide a little up or down for hood adjustment they bolt to the hinges
brooklyn ny 11234
the allen head bolts screw in them on the earlier cars like 74 75 cars
Problem # 1: Inability to adequately describe problem # 2:
the engine lid missing one nut for hold down there are 3 instead of 4 no damage to hole is still the same size quick fix for replacing the nut thx in advance mike this is the nut that goes inside lid i think they might slide a little up or down for hood adjustment they bolt to the hinges the allen head bolts screw in them on the earlier cars like 74 75cars. ![]()
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Better communication.......
I think the loose nut is the one behind the steering wheel.
930 - It may help the forum if you add location information to your public details, so that we can work through any English issues and better be able to help you. Thanks.
Mike White 1972 911E Coupe (with 2.7 and 40 IDS and SSI) |
brooklyn ny 11234
hello again and thx for all your help but i solved the problem i drilled thru the other side of lid and put a number 10 bolt thru and caught it under the lid right thru the hinge perfect drill first time with a big washer and nut now i have the right amount of bolts holding the lid down above the motor again thx for all your help i dont know what i would do if not for pelican
Glad to hear that you solved the problem.
I hate to even ask but...... What do you mean you "drilled through the other side of the lid". ![]() All I can picture is a large bolt/washer protruding through your hood looking completely hillbillyish.(No offense to any hillbilly Pelicans that may be reading this thread, of course.)
brooklyn ny 11234
oh so you do know what im talking about before you didnt
I replied early in the am and was not back on Pelican until the evening so I just now saw your responses to the other posters. Again, I'm glad you were able to solve the problem.
LoL...Careful what you get yourself into, Wayne
brooklyn ny 11234
well i still havent fixed it
Senior Advisor
Are you babling about the hinge bolt that attach the engine lid to the hinges? if yes then choose 2, If not choose 1, if neather, choose 3.
08 Cayenne Turbo |
Oh, it sounded as if you had. Well, good luck on fixing it. Sorry I couldn't be of more help.
a.k.a. G-man
But I'll try and tackle this problem nonetheless... Step 1: Like mentioned before, Your typing is HORRIBLE! Please use the shift key on your keyboard to type capital letters for each beginning of a sentence. Consequently, use a point ( . ) to indicate the end of each sentence. If you type all sentences directly one after the other without indicating beginning or ending it kind of makes it difficult to read and understand what your problem is in the first place. Please apply step one in this thread but also in ALL future posts you intend to make. Step 2: it is always good to post pics as an extra aid. A pic says more than 1000 words (10000 if you type like you do....) We would like to help but you make it kind of difficult. Please tell us you did not drill through your decklid... ![]() Is your problem solved or not?? In one post you say it is and in the next it isn't anymore.....
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 09-13-2010 at 08:38 AM.. |
brooklyn ny 11234
I choose 2
Thread Tools | |
Rate This Thread | |
