When checking oil where should needle be on temperature guage?
Should it be by the red? In the middle? Just trying to get a proper read.
thanks
Old 09-15-2010, 10:44 AM
gtc gtc is offline
abides.
gtc's Avatar
Wherever it settles during normal driving.
Graham
1984 Carrera Targa
Old 09-15-2010, 10:54 AM
about 194 degF.... typ 8 o'clock. All gauges are a bit different. Helps if you post which model year car you have.
Tip....ALL 3 things needed for proper oil level reading.
1.) on level ground.
2.) engine running ...at temp ( 194 degF)
3.) engine running at approx idle speed.... 800 RPM +/- . Even 1100 will cause a dip ( level gauge) down into red zone.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-15-2010, 10:55 AM
porsher
aston@ultrasw.c's Avatar
This will help you convert needle position into degrees C
911 Gauge module overlays
Then you can decide what temp is OK for your conditions.
Great product BTW
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 09-15-2010, 10:57 AM
