jbscheff's Avatar
Trick for Removing Fan Controls from Dash?
The controller for my ventilation fan is no longer working so I need to remove it from the dash to troubleshoot it. I know there is a bolt on the forward bulkhead holding it in. Are there any tabs or anything else, or a trick to removing it without damaging the face or the trim? Also, are there any recommendations for dealing with the cables? I'm hoping that there will be enough slack that I will be able to disconnect them from the controller without disconnecting them from the fan or the vent valves.
Thanks for any help.
Jason
'73 911 Carrera RS clone w/3.0
Old 10-26-2010, 07:59 AM
there's not a lot of room to get it out easily. once the one bolt is out, work it to the left and try to get the right side to pass through the opening. it's a bit of a struggle. then if you have tiny little hands, there's a minute chance that you can disconnect the cables from the unit. otherwise, leave them connected and deal with them up front. not my favorite job.
206 637 4071
Old 10-26-2010, 08:22 AM
Eddyvdw's Avatar
Leave it in. Remove a seat and work laying on your back, head under the dash.
Worked for me. Very likely one of the cables got stuck / bend. Also don't forget to check the ground connection.
Ed
Old 10-26-2010, 08:35 AM
jbscheff's Avatar
Got it!
Thanks for the help, I got the control head out of the dash far enough that I could work on it. This thing had stopped working for the previous owner (my father-in-law), and his mechanic couldn't figure it out, so they cut all the wires and rigged up a toggle switch under the dash. It's been bugging me ever since I got the car.
I reconnected all the wires and cleaned up the contacts. They had 37 years worth of grime on them and so their electrical conductivity was greatly reduced. They were also worn away in some places. I had to bend the wiper a bit so it would hit a different spot. Now it all works like it should, even the light for the fan!
Jason
Old 10-28-2010, 03:56 PM
Throw it on the ground!
These pics may help:
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 10-28-2010, 04:13 PM
Man does that ever look like a PITA!!! I was kinda hoping to hear this was an easy fix. My fan works fine but the other two sliders are crap, they hardly move and won't stay in place when they are moved. It looks like getting that thing disconnected and out of the dash is gonna be a chore.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 10-28-2010, 06:37 PM
Ambitious Outsider
sabeo.m's Avatar
easy access to the slider control cables underneath dash by removing the druck press and tachometer-gages. you can easily put your hand in the opening in the dash to get to the cables. I also have to remove my control box, my cables are bent.
1988 3.2 Cab
2005 997.1 C2S
Old 10-28-2010, 06:50 PM
KTL KTL is online now
Schleprock
KTL's Avatar
That control unit is a marvel of translational lever movement.......
Sabeo, my offer still stands to have whichever cables you need from my '79 racecar. Removed the control unit a few months ago and I have a bunch of good useable pieces stored in a box
Kevin L
'86 Carrera "Larry"
Old 10-29-2010, 08:58 AM
AutoBahned
RWebb's Avatar
Originally Posted by mickey356 View Post
Man does that ever look like a PITA!!! I was kinda hoping to hear this was an easy fix. ... gonna be a chore.
welcome to the world of owning an exotic car - esp. an old one
the 911 is actually easier to work on than other cars it can beat on street or track...
Old 10-29-2010, 01:06 PM
Ambitious Outsider
sabeo.m's Avatar
Ok I appreciate that, I'll let you know, thanks!
Old 10-29-2010, 05:46 PM
