Jupiter 911
bklyn's Avatar
Cyl. temp sensor question.
Getting ready to change out the temp. sensor on my 87 Targa, I have read a few of the post and it appears straight forward. My question, is the special socket needed and if so what is the size? Can I cut one of my own using an old deep socket? Thanks Lenny
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 10-30-2010, 01:14 PM
Walt Fricke's Avatar
Don't need special socket to remove, just cut wire off. Yes, you can slot the side of a socket, same as the tool, to reinstall without damaging the wires.
I remember having the most trouble with the nice rubber wiring gasket, either getting it out or the new one back in. I wasn't able to make a neat job of it in any case. Disappointing for a guy who thinks he is handy mechanically. But no issues with the sensor function.
Walt
Old 10-30-2010, 03:27 PM
Did you ohm it for the resistance? That would be your only reason for change.
Bruce
Old 10-30-2010, 04:13 PM
Jupiter 911
bklyn's Avatar
Bruce, what should the resistance read, I can not find it in the Bentley only the speed sensor and o2.
Old 10-30-2010, 04:22 PM
Bruce
If the sensor was the older style one with only one wire terminal in the socket, that would be a reason for changing it. Before it fails.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-30-2010, 04:27 PM
Jupiter 911
bklyn's Avatar
Yes, it still does have only a one wire set up that was my oring. reason for ordering a new one.
Old 10-30-2010, 04:29 PM
rvctyjim's Avatar
Yes...
14mm deep-well socket,3/8 drive,6 point.
You will have to grind one side down to the base of the socket...Works great!
86' Euro M491 Targa
Old 11-01-2010, 10:29 AM
