No worries.....ships out this week and you will love it. regards al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I should be receiving mine next week then promptly leaving for two weeks on Saturday. The pain is real.
Wow! I'm really impressed by this. I'm starting to plan out a project and was thinking a lot about building my own EFI and in my mind it pretty much looked like... well... THIS!
Thank you for sharing this! You just might have a future customer, if I can ever get my butt in gear with my build. |
regards, a
Wow, thanks for the interest. I believe that I've gotten back to everyone..... but if I missed you somehow, please pm me.
regards, al
Hilbilly Deluxe
Digging this back up,
Are Speed Triple TBs still worth investigating? What are the options for intake manifolds for them these days? I was looking at the CCM manifolds, and they seem like an easy button, except the description says "38mm port at head" which seems like an odd number, as the only engine I can find with that size intake ports (according to Wayne's book anyway) was the 906, or a factory race engine from 1971. My car is a Late SC with 34mm intake ports. Thanks, |
I no longer offer the Triumph ITBs in my kits.....I do however have a great alternative...please PM me and I'll provide a link.
regards, al
With your 34mm heads, that will certainly limit power with anything, not just these ITBs. I would highly suggest opening them to 38mm if you're going to use this setup, otherwise there's really no point IMO.
No physical quantity completely explains its own existence |
Hilbilly Deluxe
Thanks, Quote:
I did contact Clay through his web site, he said that PMO makes a tapered heat insulator from 38 to 34mm, which should be a workable solution to that issue. |
I actually addressed the same question in a related post..
"There may be some benefit to the direct-to-head design over the Triumph, PMO, Weber type manifold design, but I suspect that it will be negligible for all but the most dedicated track machine........more of a different strokes, I think. I was the 1st or one of the 1st to adapt the Speed Triple ITBs to Weber manifolds/911 engines. When I started.... this was a great, economical method for providing DIY EFI systems. After many years of successful installs.....many have seen the value, but there is diminishing supply and rising prices for the Triumph ITBs. I saw this coming a couple years ago and knew that if I wanted to continue to supply a nice system for reasonable prices, I would need to search for an alternative.....I started working with RHD, hoping to end up with a great alternative system, that was designed specifically for the 911 and did not need to be adapted...and could be offered at similar pricing. ......and I believe that we did it........." The work at RHD continues and now we can offer several sizes of t'bodies to closely match the intake ports and engine requirements.......and they are pretty effing cool too!!! regards, al Quote:
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 09-02-2019 at 09:26 PM.. |
Hey Al, is there a comparable system available for us 4 cylinder guys?
I have a frankenmotor in my 912, a 2.2 liter Type 4. Will the RHD throttle bodies fit my manifolds/spacing? thanks! Adam912.Out. '66 912, 495K miles, 2.2L of lightweight, Type 4 power |
The typical RHD throttle body is Weber DCOE pattern regarding the manifolds they will fit. |
there is a comparable system for the type IV. I've just bought a Type IV for this very purpose and I've been researching. PM me with your email address and I'll email you some info. regards, al
Thread Tools | |
Rate This Thread | |
