RSR fenders - I need some advice
I'm planning to build a '73 RSR clone based on my '75 911, which has welded Turbo front fenders (they are in good shape). I see three solutions to get RSR front fenders:
1: I can try to find some early front fenders and cut off the part under the headlight and weld this part on my g-model front "Turbo" fenders (a lot of welding to do this right, I guess)
2: Buy two new early front fenders and Turbo flares from Dansk and sell my "Turbo" front fenders
3: Buy a couple of RSR fiberglass front fenders from Getty, Rennspeed or another supplier and sell my "Turbo" front fenders
What do you think would be the best solution (quality, price etc.)? Perhaps, I should mention, that I can't do any welding myself
Mikael
Old 11-19-2010, 01:42 PM
Platinum Member
dad911's Avatar
Street car or Track car?
For the street, I'd stay with steel. Late 74' up to Early 69'-73' fender conversion thread
I wonder if you could do it with 'structural adhesive' instead of welding?
Old 11-19-2010, 03:30 PM
It will most of the time be used as street car and some times for track days
Mikael
Old 11-20-2010, 07:36 AM
I am no pro but after reading about fiberglass gel coats cracking as they age I would probably try to stay with steel. The weight saving for the fenders is not huge anyway. I would probably go with fiberglass hood though to save on some weight.
I think some of the carbonfiber stuff offered today is very high quality but I have no clue how to fit that stuff if it does fit correctly..... I mean what do you do, put body filler on it?
Old 11-20-2010, 08:12 AM
Platinum Member
dad911's Avatar
Then I would stay with steel. Did you read through this link ? Late 74' up to Early 69'-73' fender conversion thread
Don't be afraid of the welding. You could get a shop to do it, or invest in an inexpensive mig welder, and sell it when the project is done.
Old 11-20-2010, 08:16 AM
chris 964's Avatar
A big wing conversion using fillets..
Update C4 RSR Project
Old 11-20-2010, 09:04 AM
Plavan's Avatar
Stick with steel. You will thank yourself later (Fiberglass WILL crack)
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 11-20-2010, 09:14 AM
