1986 Targa 1972 RS clone
magnuskgc's Avatar
Fuse box help
Ok so the previous owner had replaced the fuse box.. I have been hunting gremlims for a while now..
I am going to have to get the wire diagram to check all of the connections, but in the mean time.. anybody see anything odvious wrong in these picture? there a few wires disconnected at the bottom of the fuse box... can anybody help with a simple solution?
Old 11-24-2010, 02:52 PM
Platinum Member
dad911's Avatar
I assume that's the '72?
'71 & '73 wiring diagrams here: Pelican Parts - Porsche 911 Parts Listings & Diagrams
Probably no shortcuts, other than finding someone with the same car and comparing them side by side.
Next best solution would be to trace the wires and compare to the diagrams.
Old 11-24-2010, 03:20 PM
magnuskgc's Avatar
not it's the 85.
Old 11-24-2010, 03:27 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by magnuskgc View Post
not it's the 85.
Here's a pic of our '86.
Check your Bentley for compatibility.
You may pm me as needed.
Your fuses look a bit "used".
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-24-2010, 03:49 PM
magnuskgc's Avatar
thanks.. that is exactly what i needed to compare... and yes the fuses look horid! I the next thing on the list is to clean up the whole box and new fuses.
Old 11-24-2010, 04:07 PM
Gary H 1978 911 SC
I think you may have a corrosion issue on top of any other issues. I see every shade of corrosion in the first picture.
Old 11-24-2010, 04:24 PM
86 may differ slightly from 85.....
Here are some photos of my previous 85.....needed 3 shots. Notice not completely stock since I wired-in the headlight relays. Should otherwise be stock. Only mod is lower grey wire shift to allow fog lights to be on whenever parking lights are on. Shots run front-to-back.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-24-2010, 05:19 PM
magnuskgc's Avatar
OK so this brings up another question.... what is the best was to clean off the contacts? or should I just replace the fuse box?
Old 11-25-2010, 09:13 AM
steely's Avatar
Ink eraser, or fine grade emery, rose paper, steel wool - with Battery disconnected. I don't use solvents.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-25-2010, 09:23 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Why not replace the whole thing with modern fuse holders? I've done it it's not that tough
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-25-2010, 09:36 AM
theiceman's Avatar
.. because that fuse holder is part of the lore ... another eclectic thing that makes up a classic 911..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-25-2010, 10:23 AM
