ccu transistor
Hello-I have been reading up on 964/993 ccu troubleshooting in the archives. If the ccu fan does not shut down after an interval-the fault is usually a bad control transistor, identified as BC 337. Where can you get one of these? Thanks
Old 12-13-2010, 04:23 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Where are you located?
Try All Electronics in North Hollywood, they got allot of stuff you can't normally find at a standard electronics supply.
Found a ridiculous transistor no one else had, I mean a whole bucket full and cheap too.
'85 Carrera Targa
PCA/POC
Old 12-13-2010, 08:15 AM
tharbert's Avatar
When I replaced several components on my RPM transducer, I bought all the replacement parts from Jameco.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 12-13-2010, 08:23 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
There is always Digikey.com if your local electronics store doesn't carry what you are looking for. It's .44$ at Digikey but shipping and handling kills the deal when you order small quantities......
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-13-2010, 09:19 PM
ccu transistor
Thanks guys! I know absolutely nothing about transistors-are these available from radio shack? If not - how do you go about ordering one from the above mentioned sources? How do you specify what you want? Thanks
Old 12-14-2010, 08:18 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you look up "substitutions or replacements" on the net...you might find a common replacement for yours.
If it's a plain old transistor....go for the sub...
Just checked myself....a 2N3904 is a direct replacement.
Just be sure of the correct Emitter/Base/Collector configuration.
Bob
Bob Hutson
Old 12-14-2010, 08:24 AM
