Hi,
I lost the key for my factory lock nuts that I got from PP. I called PP, they said that they cannot order a replacement key, I went to the dealer, same story... Why is there a key code on the package then... Anyway, the local shop tried their tool and it wrecked the stud and did not take the locking nut off. Anybody has any way to do this or am I the first idiot to lose the key on these cars... Thanks for any help!!
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
This should work.
Sears: Online department store featuring appliances, tools, fitness equipment and more
57 Porsche Speedster Replica 69 VW Squareback Automatic 80 911 SC Weissach 06 Cayman S |
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
If it is a Porsche locking lug nut that takes the key socket, most dealerships do have a master set of key sockets; 2-boxes worth the time I needed to get one.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
Non Compos Mentis
I've purchased a few parts cars that did not come with the key for the lugs.
A 3/4" circle cutter with the pilot bit removed is perfect for cutting off the locking lug without harming the lug itself. |
Yes,
It is the porsche one like the one in the picture... The one they either sell at the dealer or on PP. The local dealer tried their "master" keys and nothing worked... They were not very helpful. I'm a bit scared of the damage on the FIKSE wheels using the circle cutter... it does not damage? Thanks!
The dealer did not try hard enough. I used to have just one key so I took the lock off the wheel and took it into the dealer. They tried the set, and found a match, and ordered a key for $25. Easier at the counter than at the curb. Trust me on that one.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Non Compos Mentis
I get a lot of these, just hammer on a socket that fits over it and hit it with a breaker bar, they will come off. Agreed the dealer didn't try hard enough.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
+1 on the hammering on a socket used this many times on many different types and always works
the snapon wheel lock removal socket works everytime for me...ive removed 50+ of them with it, if fits over the part that has the notches for the key, if you only get a socket over the top part 9 out of 10 times that part breaks off
Here's the Snap-On socket -- spendy at $50 for a single socket
TSR600, Socket, Locking Lug Nut Removal Here's a whole set of damaged nut/bolt removers from Sears for $60, with a bunch of different sizes. Sears: Online department store featuring appliances, tools, fitness equipment and more If it were me, I'd try the Sears kit, but I wouldn't just slap on the removal socket and try to spin the lock off. Instead, I'd use the smallest socket possible to be sure it "bit" tightly into the lug nut. Then I'd put a long breaker bar on it and slowly and steadily lean on it until the nut started to loosen. No impact wrench. If the lug nut sheared off while doing this, then I'd just drill it with a hole saw. Lots of people have recommended using the hole saw method for removing broken lug nuts, including John Walker. And the "upside" would be that I'd have a cool damaged bolt/nut remover kit in my garage. ![]() HTH. Let us know what you do.
1984 Targa Last edited by scottb; 12-25-2010 at 07:14 AM.. |
X3. This will work. Use a cheap old set of sockets and hammer away. Wheel will be fine if you are careful and it will come right off. Been there done that...
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
nope, sorry. those nuts are designed to shear off the top part and leave the bottom part if the socket trick or snapon lug nut removal tool is used. so that's the first step to removal. the second step is to use the 3/4" deep hole saw carefully on the bottom part.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-25-2010 at 07:46 AM.. |
RETIRED
JW has the right suggestion.....hope you have decided like most of us to NEVER buy locks again. Waste of time if ya ask me. All they do is piss off the owner.
Rarely do they protect from theft.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Take it back to the dealer and ask them to LET YOU try out the master kit. It will take you 1 hour to try all 25 of them but you WILL find a fit. Then buy 2 spare ones, one for the tool box in the garage and one for the glove box in the car.
They have a master kit, you just need to waste your time and not theirs.
Where did you find one for $25. Only 1 dealer is willing to sell me one and for $50. Seems pretty spendy for what it is.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
its a tiny lock. Should be easy to pic. Look at a U tube vid on how to do it. Prob take a first timer 30 mins for the first one and 5 mins for the others.
Chris 89 Carrera |
Lug bolts on 986/996 and later cars are completely different than the locks on the lug nuts
