Help needed troubleshooting air conditioning
Hi All,
I've trying to diagnose my air con woes. Evaporator blower works fine on all speed settings. But:
1. Compressor does not engage
2. Front condenser blower does not work
There is no voltage at the compressor, nor the front blower.
I've just replaced the relay next to the evaporator to no success.
Can someone please help me with what needs to be checked next?
Thanks,
Adam
_____________________
'73 RSR Interpretation
Old 12-29-2010, 01:22 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by StayGold808 View Post
Hi All,
Thanks,
Adam
Adam,
Fuse #2 tends to run hot.
Fuse #2 (check for corroded fuse or poor contact).
Also, voltage on both sides of the fuse.
You may pm me as needed.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-29-2010, 09:26 AM
Detached Member
Hugh R's Avatar
Don't know your car, but does it have a Hi-Lo pressure switch for the freon? You might be low on freon.
Hugh
Old 12-29-2010, 09:27 AM
Here's another thought.
Check the relay located in the smuggler's box. (see pic).
If you need to replace, buy this one.
Which provides power to the condenser relay.
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-29-2010, 10:06 AM
They did by '86. The older ones w/ the York compressor did not.
Nothing; no power when you jump the compresser?
Old 12-29-2010, 02:07 PM
Thanks for all the replies...
Found the problem. It was the thermostat in the centre console. When I jumpered the connections to bypass the thermostat, everything worked fine.
However, I noticed that the voltage to the front condenser blower is only 7 volts. Is this normal? Also, where is the front condenser blower relay?
Thanks,
Adam
Old 12-29-2010, 04:43 PM
Thanks,
Adam
Adam,
The voltage should be 12-13V
Here is your relay/fuse location.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 01-03-2011, 12:28 PM
