tomeric914's Avatar
What is the difference between the brown and black chain rails / ramps / guides?
Just curious and can't seem to find the answer. What is the difference between the brown and black timing chain rails / ramps / guides?
EDIT: Hang on, I think I see now, the black rails appear slightly "taller" than the brown rails.
It appears that the PO replaced all the rails with the brown version.
Anybody know the torque value for the ramp bolts?
EDIT: Found it; inner chain ramp bolt torque value is 18.4 ft-lbs.
Anybody have a good picture showing the correct ramp orientation?
Old 12-30-2010, 01:00 PM
black tall, brown short. brown goes in the right lower engine case. long ends point to the closest sprocket, so in the case, long ends inward, in the chain housings, outward.
206 637 4071
Old 12-30-2010, 03:08 PM
tomeric914's Avatar
Thanks JW! Actually, I just looked again and 5 are brown, one is black (the inner bottom right) AND the long ends were pointing outwards on the inner case rails! Talk about assbackwards!
Is there a specific torque to the inner ramp bolts?
Old 12-30-2010, 04:08 PM
Tight, but not too tight...
Bruce
Old 12-30-2010, 04:33 PM
Tori's Avatar
Is there a "set in stone" color and position for these ? I have 2 browns on the inner passenger bank, and one brown inner drivers side. The rest are black.
As far as i can tell, this motor has never been apart.
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 04-16-2017, 05:59 PM
proporsche's Avatar
Hi Tomeric..you have to have all black and only one brown.....
Hi...Tori here is the diagram how it is done correctly.. no any other-way.....
Ivan
Old 04-16-2017, 11:00 PM
Tori's Avatar
Thanks Ivan, that clears it all up.
Wonder why these motors are getting put together with the wrong parts ? Weather it be from the factory or independent repair shop.
Old 04-17-2017, 07:27 AM
proporsche's Avatar
Hi Tori..the problem is that everybody wants to be 911 mechanic...and if they are it is just by working on the 911`s but not really mechanic theories from school..in their brains...
Ivan
Old 04-17-2017, 09:55 AM
Tori's Avatar
HA! I love working on stuff,....... but believe me,....... being a 911 mechanic was not on my list.
Old 04-17-2017, 09:57 AM
proporsche's Avatar
What i meant is as you said..... you go to shops and there are those wanna bees..not a regular dude who works on his 911 as a pleasure.......
To these people i always like to help to....
Ivan
Old 04-17-2017, 10:03 AM
Tori's Avatar
oh i knew what you meant. I can't see being a shop owner/mechanic actually being able to charge enough to cover what's needed in caring for one of these motors properly. PHEW ! Lots and lots of time involved.
Much appreciate the quick advice btw !
Old 04-17-2017, 10:19 AM
