side marker delete = fast turn signals
Hi All,
After deleting my side markers, my turn signals flash fast, as the relay thinks a bulb is blown. Is there any solution for this other than adding resistors into the system? Thanks, Adam
_____________________ '73 RSR Interpretation ---------------------------------- |
sudo apt-get purge 930
Not that I know of, I would just add resistors and be done with it.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Formerly known as Syzygy
Or an electronic flasher. There's just not enough electrical load to flash at the correct speed. The same thing happens with LED lights.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
my turn signals flash fast all the time, too. I've never had side marker lights.
I just thought that's the way this car was made. Or do I need to fix something , too? All the bulbs are good.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Senior Advisor
The problem is you guys have the Japanese-type flasher and you need the ROW type flasher installed. The Japan flashers are real popular with the tuner crowd and they go for a premium so don't throw them out (can't remember the p/n). Just make sure that you ask for the ROW type flasher when ordering.
08 Cayenne Turbo |
Resistors are cheap...
i've got an electronic flasher that is designed for LEDs, but its max load is 20A.
So i'm thinking it would burn out with normal bulbs. I have R lights, so i think each of those indicators are 8A. I think the front turn signals are 10A each.
10A is quite a lot. What's the fuse for that cct?
sorry... i realised i meant watts, not amps.
So amps = wattage/ voltage i know the rear R light bulbs are 18W each. I vaguely remember the front bulbs being 21W. Need to check that. But if that's the case, my setup will draw only 6.5amps. I'll have to check this, but sounds promising =D
_____________________ '73 RSR Interpretation ---------------------------------- Last edited by StayGold808; 12-03-2009 at 08:52 PM.. |
Porsche Owner
okay so has someone fixed the fast blinking problem? i bought the side marker deletes and would like to plan ahead on installing them. if anyone can do a step by step walk through thatd be nice. thanks.
1987 Carrera - 2008 Cayenne Turbo |
Carrera Cab Connoisseur
Try increasing wattage of both front and rear to compensate for the side marker delete.
Dave 1986 Carrera Wide Body Cabriolet 1993 Nissan 300ZX Twin Turbo (620rwhp) 2003 BMW 330Ci MSport Individual 1973 Mercedes 350 Custom Convertible |
UnRegistered User
You might want to watch the plastic inside and outside the light housing if you increase the wattage. More watts = more heat = melted plastic.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Those with the fast-flasher problem need to change your flasher relay: Note: This relay might not be the correct piece for your application. You need to see which relay replaces your existing relay. |
