83 911 Production Cab #10
JJ 911SC's Avatar
While the 915 is out. What else should I do
Now that the cleaning phase is completed, while I will not be going in... beside replacing the Guide Tube O ring and Shaft Sealing Ring, anything else I should consider.
JJ
Before:
5 Hrs, 2 Toothbrushes, a roll of paper towel & 4 rags later:
Who Will Live... Will See
Old 02-11-2011, 04:49 AM
6 cylinder symphony
Transmission mounts - I'd change them as well.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 02-11-2011, 05:20 AM
jmccam's Avatar
Very nice.
1983 Porsche 911 SC Coupe
"We will either find a way, or make one" - Hannibal
Old 02-11-2011, 05:22 AM
grateful user
don gilbert's Avatar
I would at least put a new throwout bearing and pilot bearing in. Cheap insurance. Inspect the arm really good for cracks or warpage. The plastic bushings for the pivot are easly replace to.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 02-11-2011, 06:07 AM
Home of the Whopper
Throttle linkage thingy bushings?? PP has brass ones.
I really like the picture where half is clean. Shows a dramatic difference.
What did you use as a cleaner?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 02-11-2011, 06:08 AM
tobluforu's Avatar
Is the motor out as well, if so what year? I'm amazed at the difference-looks great!
Old 02-11-2011, 06:15 AM
MBruns for President
JeremyD's Avatar
+1
I'd also look at either replace the trailing arm bushings or installing monoballs.
Old 02-11-2011, 06:30 AM
Drisump's Avatar
JJ you're going to have to install a mirror floor in the garage....WOW.... Q-tips?
Old 02-11-2011, 06:31 AM
JJ 911SC's Avatar
Thanks for all suggestion and comments.
No, the mirror is staying above the bed
The engine and transmission are 1986
The transmission and engine mount have been change.
The clutch cable is being change
Porsche Short Shift kit going in
All bushing being change
New clutch kit going in along with new throwout bearing and pilot bearing in
Probably will not meet my target date of 1st of April to be on the road
The cleaner is Facto AT-30 from http:www.swishclean.com/clean-itcenters.htm?ECINFO=//SWISHLOCATIONS (Canada/US/Europe)
Less than $5 a Liter in a 20 liter pale.
[/QUOTE]
Old 02-11-2011, 07:46 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Re-facing flywheel and replacing the rear crankshaft seal is an option.
Old 02-11-2011, 08:47 AM
grateful user
you could also put this brand new never been used PMS forged flywheel in to. For real cheap. If you were so inclined.
Old 02-12-2011, 09:03 AM
JJ 911SC's Avatar
[QUOTE=don gilbert;5842516]you could also put this brand new never been used PMS forged flywheel in to. For real cheap. If you were so inclined./QUOTE]
PM on your way
Old 02-12-2011, 09:12 AM
+1. I would at mimimum take the pivot shaft out, and grease it with good grease. There is a very special grease for the clutch splines. The splined shaft section must be clean, and make sure the two slide smoothly.
Old 02-12-2011, 09:48 AM
grateful user
got your pm jj, and noticed in your garage that "the babe" has a 3.2 . this flywheel is for a 3.0 engine. You need to find out if it will work on the 3.2. it might, i just dont know.
Old 02-13-2011, 04:27 AM
JJ 911SC's Avatar
OK
I'm taking advise on this one but... I'm afraid that I know the answer.
While the clutch brige the 83/86 year, the flywheel seem to be more specific;
911 Flywheel (1974-77), New
Brand: OEM [More Info]
911 Flywheel (1978-79), New
911 Flywheel (1980-83), New
911 Flywheel (1984-86), New
911 Flywheel (1987-89), New
I hate passing a good deal...
Old 02-13-2011, 05:04 AM
grateful user
oh well. good luck on the engine, looks good.
Old 02-13-2011, 08:22 AM
