danishcarnut's Avatar
Engine decode
Anyone who can help me decode this engine ??
911/07
9011061015R
Casting: 6117394
Thanks......
Regards, Heine Hansen
http://www.carnut.dk/us - http://www.policecar.dk
http://www.youtube.com/user/danishcarnut
1963 Mercury Marauder - 1974 Porsche 911 2.7
1961 Porsche Speedster "Replica" - 1971 Plymouth Fury - Walnut Creek P.D.
Old 02-15-2011, 08:17 PM
RETIRED
Joe Bob's Avatar
911/07 70/71 2.2 911T engine 84x66, 2195cc I 46, E 40 I 32, E 32 8.6:1 125 hp @8500rpm 130 lb/ft @ 4200rpm
2012 ML350 3.0 Turbo Diesel
Old 02-15-2011, 08:27 PM
Canyon Runner
70SC's Avatar
1970-71 2.2 for USA 125 hp 130lb/ft torque. with Zenith 40 carbs. What's up JB ?
Old 02-15-2011, 08:28 PM
Thank you guys. That as quick !!
I bought the car/motor as a 2.7, but seller said that the case have been changed at some point, and all other parts from the 2.7 bolted into it. Is it possible to interchange the cylinders etc. on these, and make a 2.2 a 2.7 ???
The injection etc. from the 2.7 is all there.......
Old 02-15-2011, 08:35 PM
RETIRED
Joe Bob's Avatar
2 slow, Beavis....
Old 02-15-2011, 08:58 PM
Grady Clay's Avatar
Yes … but it is a LOT of work.
Typically not done due to expensive machine work and (usually) better alternatives.
The cylinder spigots would have been enlarged to fit the 90 mm bore cylinders.
There would be needed hand-work inside the case to clear the rods and piston skirts.
Check under the engine for iron (2.2T) cylinders or aluminum (2.7) cylinders.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-16-2011, 05:24 AM
Thank You very much for the explanation, Grady.
Old 02-16-2011, 01:30 PM
